06-12-2009, 07:36 PM | #1 |
Bloodied Knuckles
What are you guys doing with your np205's?
Hi everyone,
Happy Friday! I was wondering what popular modifications everyone is running with their np205's. Ive been thinking of throwing on a set of these http://jbfab.net/Merchant2/merchant...._Code=Shifters whatcha think? I have been reading a lot about clocking rings and stuff I don't understand. So maybe if your guys can tell me what mods your running and what the mod does in lamens... That would be cool!! Last edited by Eturnit3; 06-12-2009 at 07:37 PM. |
06-12-2009, 08:13 PM | #2 |
Arrived on a Pale Horse
Re: What are you guys doing with your np205's?
what, may I ask, is wrong with your stock shifter. It has been my understanding that twin stick shifters only come into play with an NP205/203 Doubler t.c.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
06-13-2009, 02:42 AM | #3 |
you can twin stick a 205 but it just makes it so that you can use one stick for 4 wheel drive and 2 wheel drive and one stick for high and low range its been awhile since i have seen one to remember how it was done but i know you can do it
03 duramax 6sp. 4x4 cc sb Last edited by duramax3388; 06-13-2009 at 02:46 AM. |
06-13-2009, 10:39 AM | #4 |
Nothing, just 15yrs of wheelin it
Changed the gear oil & painted it..oh and added a washer to the linkage mount to take some slack out.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
06-13-2009, 12:55 PM | #5 |
Kid's Mechanic
I have thought about doing the twin stick thing to my mud truck.I think it would help me and there is a certain cool factor to it also.My axles are locked.Some of the places I run there is some tight turning so I'm in and out of 4by.The difference is about a 1/2 inch between 4by and 2by with the factory shifter and the ground is usually pretty rough. I really want something with a longer throw so in low light conditions you can just reach over and "feel" that it is in 4by.2/3rds of the races my class runs are in the dark.
06-13-2009, 08:51 PM | #6 |
I`ve never done a ding dangley thang to a 205.Neffin,I tellya...ceptin`paintin`a couple-few here or there.
06-13-2009, 09:02 PM | #7 |
Bloodied Knuckles
Negative with the kit I posted you can use front wheel drive only or rear wheel drive low...requires internal mod and to the shift rail as well... no one running clocking rings or nothing?
06-13-2009, 11:33 PM | #8 |
Beatin the snot out of it pushin a Boss V-Plow!
06-16-2009, 01:28 AM | #9 |
I do know that I need to replace some seals. After that, clean, then paint. Though, I need to replace every other seal too. Except axles....
06-22-2009, 06:10 PM | #10 |
Years ago I made a twinstick set up on my orange blazer. I use 2 low all the time when I'm "wheelin". Most of the time you don't need 4wd but being able to drive in low range 2wd is nice. When I made my set up they didn't sell a kit yet. I came across an article in Petersons a few years ago on how to modify your stock shift rail. I have never got around to doing this. Without modifying the rail you can't use front wheel drive only. At least I'm guessing thats why I can't on mine.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
06-22-2009, 10:59 PM | #11 |
Bloodied Knuckles
yeah I found modified shift rails..
http://www.offroaddesign.com/catalog...seshifters.htm |
06-23-2009, 01:21 PM | #12 |
Mostly I'm just adding gear grease to mine... need to fix that leak!
I twin-sticked mine when I swapped it in to replace my blown T-221. I did NOT make the internal mods. So I have 1 stick that is HI-N-LO for the rear axle & the other stick is HI-N-LO for the front axle. W/O the mod, you must move the rear shifter, and then the front. To come out, you have to move the front shifter and then the rear... Did I need it, no, but it was only $20 more than a new single stick kit, and the X-fer I got had no shifter. Mostly, it's a cool factor in my truck. I'll never use it to drag the back end around. If I ever open the X-fer up, I'll make the mod. Again, don't need to, but want to.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
