Old 06-12-2009, 09:02 PM   #1
MR C
Question Transmittion Question
I have a 63 c20 with a bull low 4 speed that whines. I also have a c30 school bus with a 5 speed. I think it is from the late sixtys. Would it bolt in my c20?
MR C is offline   Reply With Quote
Old 06-13-2009, 12:59 PM   #2
502tripower
502tripower's Avatar
Re: Transmittion Question
Have you checked the fluid level in the 4-speed? Might just be low.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 06-15-2009, 12:25 AM   #3
Captainfab
60-66 Nut
I think you would have to change the bellhousing. And then it may or may not have the correct mounts. That 5 speed won't give you much advantage over a 4 speed for your application. 5th is a 1:1 the same as 4th in a 4 speed.
I would check the oil level as 502tripower suggested. If the trans is bad, I would consider upgrading to the newer SM465 4 speed ('69 and newer)
Old 06-15-2009, 04:53 PM   #4
MR C
I checked the fluid and it is fine. The transmittion is in a c40 not a c30 like i posted before. I know 5 is 1to1 but it would be better than the noise in the 4 speed. I crawled under it today and it even has the same type emergency brake drum deal. Thanks for the replys
