06-13-2009, 01:54 AM | #1 |
brake/spindle question
im getting ready to order suspension parts and i got a question. right now on my truck i got 1" rotors and im wanting to got to 1 1/4" inch rotors so what is involved with doing this just get spindles that are for 1 1/4" rotors. and i shouldn't have to change the ball joints or anything.
81 gmc short box stepside(rebuild in progress) 09 mitsubishi lancer gt |
06-13-2009, 09:20 AM | #2 |
Re: brake/spindle question
i'm almost positive that the only difference is the size/length of the shaft on the spindle. for the bigger rotors the shaft is 4 1/2"-4 3/8" and the smaller rotors are 4"-4 1/4".
someone correct me if im wrong. everything else including ball joints is the same.
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
06-13-2009, 09:25 AM | #3 |
6.0 powered square
you'll need larger wheel bearings, calipers, and different brake hose
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
06-13-2009, 09:27 AM | #4 |
thanks aaron, knew i was forgetting something.
06-13-2009, 10:38 AM | #5 |
Happy to be here
You will need everything that is mounted to the spindle, including bearings, rotor, and caliper.
06-13-2009, 10:54 AM | #6 |
thanks guys thats just what i needed to know
06-14-2009, 07:31 AM | #7 |
Are the spindles, bearings and calipers the same on the 3/4 ton (knowing the rotors are different due to the 8 bolts)? Isn't the difference in the control arm side of the ball joint? A lot more scrapped 3/4's around here.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
