Old 06-13-2009, 03:03 AM   #1
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
New bed floor
So I'm just starting to think about what to do with my bed floor. My plan is to shorten from lwb to swb. The original wood was trashed so I tore it out 5 years ago, so now I need to figure out what to go back with. Wood look cool but I plan on hauling dirt bikes, tools, and whatever else comes along so that is out of the question. I would like to find a metal floor but can't seem to find them anywhere. So my next thought was build one out of some 1/8" or 3/16 plate steel and then rhino it. What do you guys think? anyone know where to get a bedfloor in northern ca? thanks!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-13-2009, 03:30 AM   #2
drivethechevy
drivethechevy's Avatar
Re: New bed floor
one idea would be to trade your wood bed minus the wood, for a steel bed
or you could get a bed floor from a different era truck and custom work it to fit your truck
otherwise if you really wanna do a truely custom floor that would have no issues strength wise, i would do a diamond plate floor, put extra suports made of 1/4 flat stock that were welded 1 foot or so apart going long ways on the bed then weld the dimond plate to those strips, then you could top it all off with rhino liner or herculiner
that would be how i would make a custombed floor
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 06-13-2009, 05:18 AM   #3
blime81
Laid Lo
blime81's Avatar
Re: New bed floor
I believe LMC still sells floors for SWB trucks. My 72 came from the factory with a steel floor.
I'd buy one from them and then herc line the inside. Looks clean and is functional as can be.
Have often thought about the D plate but that is not a cheap route.
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
