Old 06-13-2009, 06:54 AM   #1
DADS71
DADS71's Avatar
way to tell if a factory big block truck
I have a 72 super short bed ,the rumor is it was a factory big block truck but now has a 350 installed what is the best way to tell if it was a factory big block truck?
DADS71 is offline   Reply With Quote
Old 06-13-2009, 06:56 AM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: way to tell if a factory big block truck
There should be some mention of it on the SPID inside the glovebox door.
Old 06-13-2009, 07:30 AM   #3
Look for a factory exhaust bracket for dual exhaust.I`m assuming there`s no SPID.
Old 06-13-2009, 07:47 AM   #4
LONGHAIR
The SPID inside the glove box door will show an engine option. The big block was not standard, so it will be listed there as a 400.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-13-2009, 08:21 AM   #5
too much stuff
Roadtrip!
too much stuff's Avatar
Probably would have a high hump trans cover unless it is a 3 speed manual. Should have a heat shield on the bottom of the pass floor. A couple of places to start...
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 06-14-2009, 12:09 AM   #6
71 super
71 super's Avatar
Heat shield is a good place to start for sure- the bolts that hold it in place are 5/16 phillips head bolts, if things are changed usually this gets over looked. The dual exhaust hangers are another good thing to look for and the correct motor mounts should be a clam shell type if a true 72 bb truck. The fan shroud was prob. not changed out either so it will be visably different from a small block truck.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-14-2009, 04:52 AM   #7
JimKshortstep4x4
The left fender will have mounting holes for the power steering reservoir if the truck came with power steering.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
