1981 CHEVY C10
Biggest notch I can get???
Whats the biggest notch I can get on my 81 c10 without cutting the bed out??Im going 22s and bags..
Re: Biggest notch I can get???
you could always raise the bed floor and build some spacers so that you dont have to have the whole in the center of the floor. i have done this on some minitrucks we build at our shop. as far as the size of notch without cutting the bed floor im not sure. best bet would probably be to just measure yours so that you know for sure it will fit. if i had a c10 in the shop i could measure for ya. we got an 88-98 here but not sure if its the same distance to bed floor or not. wish i could help ya more. good luck with the build let us know how your notch turns out man. if i can help ya with notch designs in any way let me know.
Happy to be here
![]() Join Date: Mar 2000
Your not going to like the answer. I have posted below the biggest notch you can use and not cut your bed. This will put the pumpkin less than 1" from the bed floor.
As dough_boy suggested, your going to need to raise the bed floor, cut a hole, or run a smaller tire/wheel combo.
that mini notch looks good. thats the same thing i have done to my blazer at the moment. but that will be getting changed soon when i set it up to lay frame. good looking notch tho man
www.myspace.com/thehouseofhack www.thehouseofhack.com www.myspace.com/minitruckin_mat ![]() |
Happy to be here
8" pipe and a bit of boxing plate cleans things right up. That's my buddy Roger's work on my 77 Cheyenne.
1981 CHEVY C10
>130dB Moderator
You want to lay out and not cut the bed, on 22's?
Don't take this the wrong way, but good luck...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
1981 CHEVY C10
my honest opinion is to go with a thicker side wall. this offers a better ride over the low pros most people are running. but yea if you still are not wantin to cut your bed floor or raise it i would go with the mini notch as mentioned above man. if i can be of any help let me know man im always willing to help a fellow enthusiest out.
Happy to be here
This is as low as you can get and not cut your bed. You might get 3/4" lower but it won't roll if you do.
1981 CHEVY C10
k.so whats the thickest sidewall i can go? I wanna go wit 265/35/22.I also thought bout 285
1981 CHEVY C10
#13 |
1981 CHEVY C10
#14 |
Happy to be here
Front Size-
BFG KDW 245/40/20 VinTec 20 x 8.5 Back space 5.5” Rear Size- BFG KDW 295/40/20 VinTec 20 x 9.5 Back space 5.5”
#15 |
1981 CHEVY C10
Im goin 3/5 with 22s..Man i cant wait till my ceramic headers arrive. suppose to be here wed.Ill post pics when i get them
#16 |
N2Trux, the stance of yours is pretty similar to what Ill be running, would you be able to give me a distance from the ground to the lower front corner of the rear fender , and whats the diameter of your wheel/tyre combo ?
thanks |
#17 |
his truck is lower than 3/5
76 Chevy Fleetside 63 Lincoln Continental w/ Ford Racing 460 (550hp) 2012 VW GTI 2013 Escalade 2008 Harley |
#18 |
I have car A.D.D.
He listed his wheel and tire combo in post #14. It is a great stance. Another wonderful truck that is just so pretty in all its trim.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
#19 |
6.0 powered square
when my truck was almost lowered 9" in the rear there was about 1" of clearance with the c-notch the rear end pumpkin was a bout a inch from the bottom of the bed and the drive shaft rubbed the cross supports and if it was bagged it wouldn't been much lower
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 06-16-2009 at 02:32 PM. |
#20 | |
I'm just glad to be here!
I beleive his has a flip kit with some leaves removed along with a air over leaf bag set up. (although I believe that is getting changed now...)
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 06-16-2009 at 04:49 PM. |
#21 |
Happy to be here
Thanks for stepping in with some good info. That is correct on my rear set up except I am running a 2" block as well.
