Old 01-03-2003, 12:18 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
Question ? about hydraulic clutch and brake hydroboost pedal swap
The 1989 1 ton that I got the 454 from has a hydralic clutch setup and the brakes have a hydroboost. I'm going to swap both to the 69. As I'm pulling the pedals from the 1989, what measurements should I take so I can duplicate the pedal swing?
On the clutch, am I just concerned with the stroke of the pushrod attached to the clutch pedal or do I also need to be aware of the distance the pedal moves.
Same question about the brake pedal movement.
As always - thanks for any and all help!!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-03-2003, 10:34 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Over night I got to thinking and I guess the distance that the pedal moves is not critical as that is dictated by how far the pushrod moves.
Hopefully get the pedals pulled tonight.
