Sunburst C10!!!
brake line coils
the lines that come out of the master cylinder that go to the distribution block have coils in them
im wanting to know what these are for and if they are needed any help would be great thanks
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 06-14-2009 at 11:53 AM. |
Re: brake line coils
no you do not need them......they have 2 purposes
1) they are a maintance loop.. meaning that should there be a variance in aftermarket parts (prop. valve, master cylinder, booster/ mounting bracket) you can simpley 'un-coil' it to desired length... - also, those end fittings, get rounded (from not useing a flare wrench to take them off) and need to be replaced....so the extra coil is there just for that reason....instead of replaceing the whole line, just cut bad fitting off, install new fitting, flare, and re-connect...... thats the purpose of the coils, do you need them??? no, but you may wanna think about adding that service loop, for the above reasons, just in case. |
I always thought they were there for when the cab would flex on the frame. A service loop also makes alot of sense too. Either way I installed them when I did the brake lines on my 52.
Chris 52 Chevy 3600 (3/4 ton) 5 window pickup -54 235 Inline 6 w/ Fuel Injection Conversion -Clifford 2/4bbl Aluminum Intake and Headers -1/2 ton front axle swap w/ 5lug disc brake kit -CPP Power Steering Kit Various pictures of my 52 Chevy 3600 |
Sunburst C10!!!
im going to run them down the firewall and through the frame
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 06-14-2009 at 05:10 PM. |
I've always been under the impression that they work just as a form of vibration isolation. Steel tubing will work harden if flexed continuously and will eventually become brittle and break at the flex point.
x2. It also allows flex within the lines which help prevent premature wear. On a weekend cruizer they're not needed; on a daily grinder, the 'loops' seem to have several benefits,
Sunburst C10!!!
so can i put loops in between the cab and frame out of sight
Gage 1967 C10 Shortbed Stepside |
![]() Join Date: Apr 2005
x3. The coils spread the flex over about a foot of brake line instead of concentrating it in just one spot. You can 'spring' those coils just about forever, but bend a brake line in one spot a few dozen times and *snap*.
