![]() Join Date: Apr 2007
Will this suspension fit our trucks.
http://cgi.ebay.com/ebaymotors/ws/eB...m=290324046494
Im fairly sure it will work but just not positive.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
Re: Will this suspension fit our trucks.
I think the key word for the universal fit is "welder".
It will likely have the car bolt pattern of 4 3/4" on the rotors and springs that are too light for the weight of the truck. Check out porterbuilt's dropmember. It will fit for about the same price. http://67-72chevytrucks.com/vboard/s...d.php?t=307009 |
#3 | |
definitely cool stuff there!
I would think that the rotors could be swapped over. I bet everything would fit. Its a hell of a good deal starting at $1000! Quote:
"Universal" usually means "good luck making this fit" when it comes to street rod products.
I would spend my $1,000 on a product such as Porterbuilt's Dropmember or *****************'s Raised Crossmember ... especially considering they were designed SPECIFICALLY for our trucks. |
I watched a video on putting these things in and it was very simple. basically just needs to be cut down on the edges and welded in.
All the kits for our trucks seam to cost a fortune compared to this kit. anyone els have any experience with these set ups?
I was speaking from experience.
What did you put it in? and did you run into any issues while doing it?
#8 | |
A 1935 Ford 2 door sedan ... the main issue we found was getting the cross-member "square" within the chassis and getting the "anti-dive" angle set on the upper cups in a chassis that is not "jigged." A chassis is not as rigid as one would think once all the body components are removed.
This statement from his eBay description is what really gives me cold chills. Quote:
good point. I guess it all depends on how well someone can measure and weld then.
![]() Join Date: Dec 2008
Pinto front ends belong on Pintos...Buy the real deal (model specific) for your truck if you can.
#11 | |
Here's something that I missed the first time looking at the auction ...
Can anyone verify this for tranz am, I'm not where I can get to a truck to measure currently. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
We installed one of these kits in a 54 Chevy truck. I could see why someone would want to install one in that, but not in a 67-72. In the 54 we were converting from drum brake, strait axle, roller bearing type front end to the independent, disk brake, and tapered bearings style with rack and pinion that the Mustang II front end is. The 67-72 already has independent front suspention and wouldn't be that tough to change over to rack and pinion steering if that is what you are after. You do have to do lots of measuring, some of witch isn't strait forward. You also will have to fabricate frame boxing plates. Not that it is a big deal just not mentioned in the add. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#13 |
yea figured that frame plates and gussets would be needed. Just tought it would be a cool idea.
