Danhard under dash a/c water leak
I have a danhard underdash a/c the leaks a lot of water. primarily when i'm going around corners. does anybody have any ideas on how to stop this?
Re: Danhard under dash a/c water leak
Look for the drain tubes. If they are there, check for blockages. If not, put some on and route outside the cab.
I did find a little piece of plastic blocking the tube on the drivers side but even after clearing it I still have leaking problems. only the drivers side leaks. The drain setup is a Y where the passenger side goes straight down and the drivers side is routed to the passenger side. Pics soon to follow.
Old Skool Club
![]() Join Date: Jun 2001
Wouldn't be unusual for a foreign object (bug/dirt) to stop up a drain tube.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
OK, here is where the problem is coming from. This pictures is looking up from the gas pedal. The bottom center of the picture is where the drain tube hooks up. but no matter how tight water always spills from there. just above that there is some plastic that overlaps and it looks to me like water can easily come out of there... should I silicone this up?
![]() Last edited by davebloomer; 06-14-2009 at 10:23 PM. |
here's one a little more close up
I`d run this by Danhard.
