Parts for sale local pick up DFW Tx.
Nice set of doors with good trim, chrome vents and no rust. One of the doors has some small dents at the bottom. $300 each
Nice straight tailgate. $300 5 lug disc brake swap with drop suspension. I'd like to try and sell this as a set. Includes the following: Front crossmember with CPP upper tubular a arms, ECE drop spindles, ECE springs, new ball joints, rotors and calipers and Russell front braided brake hoses. 12 bolt open 5 lug rearend ECE adjustable panhard bar ECE shock relocators ECE 4" rear drop springs power steering box Trailing arms with rear sway bar attached. The swaybar plates are bolted but also tack welded to the trailing arms. ECE drop trailing arm crossmember ECE drop trans crossmember $1200 |
Re: Parts for sale local pick up DFW Tx.
Pics
Last pics
SWB 4x4 Collector
![]() Join Date: Jun 2001
Is the tailgate a gm gate? I might be interested if it's an original gate. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
SWB 4x4 Collector
does the tailgate have any dings in it on the inside or out? Don't be discouraged that I am in KS, my brother in law has to go down to though Texas in about two weeks for Air Force schooling and could probably meet up with you to take it.
![]() Join Date: Apr 2005
I would like the track bar and the shock relocation kit if you will separate.
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
![]() Join Date: May 2002
what is the rear gear ratio?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
if you decide to break up the set let me know what you want for the sway bar and the rearend. thanks
Could I get your number so I can call you, if you still have all the suspension and brake stuff, Id like to see if we can work a deal. Im in Weatherford Tx, or you can call me at 817-304-5417 thanks Jonathon
Are you selling the front sway bar as part of the "set" or are you selling it by itself? I'm interested if it's selling by itself or if you decide to part.
The tailgate is a GM piece. It's nice. No dents. I don't mind holding if you can pay now. Need the cash asap.
#13 |
#14 |
I Like Mine With No Shine!
![]() Join Date: Apr 2009
is the drop trans cross member for automatics? how much you want for it? would u be willing to ship it to 87107?
Michael ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17 ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=384152 |
#15 |
SWB 4x4 Collector
Is the tailgate gone yet? I seen you had it on craigslist so I didn't know if it sold yet. I will be heading down to Austin this next weekend and could pick it up. Trevor
#16 |
Still have the doors $500 for both.
#17 |
What about the other parts in the post???
#18 |
![]() Join Date: Dec 2008
Do the doors still have the glass in them?
Any major rust around the door hinges? Do the door inner metal panels come with? |
#19 |
#20 |
#21 |
Would you take $300 for the pair of doors?
#22 |
#23 |
The suspension parts are back up for sale again. 2nd time my buyer backed out.
#24 |
do you still have the trailing arm crossmember and trans crossmember? If so how much for both?
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
#25 |
![]() Join Date: Jan 2002
have you sold the suspension parts?
1968 Custom 10 SWB 1970 2wd Blazer 350/400 1972 K20 292/350 |
