Old 06-14-2009, 09:55 PM   #1
AllenKarber
Disc brake drag....
How much brake drag is acceptable for disc brakes? I know there has to be some,but how much?
Ever since I converted to discs it seems as if I get excessive brake dust. I even tried ceramic pads to help with the dust problem. This did help,but it still seems like I get too much.
AllenKarber is offline   Reply With Quote
Old 06-15-2009, 12:05 AM   #2
cajundragger
Re: Disc brake drag....
clean your calipers maybe. If you have too much junk the pistons wont retract enough.
but if I spin the rotor it wont make a full turn before it stops.
cajundragger is offline   Reply With Quote
Old 06-15-2009, 06:48 AM   #3
AllenKarber
Mine will make at least a turn so maybe they're ok?
Old 06-15-2009, 11:40 AM   #4
Shane
Shane's Avatar
disc brakes do not require the same amount of "drag" as a drum system due to the caliper having more hydraulic cylinder "travel" versus the smaller wheel cylinders on a drum system.
Shane is offline   Reply With Quote
Old 06-15-2009, 04:03 PM   #5
royo
royo's Avatar
2 lbs on the disc. 10 or more on drum
nickle and dime
royo is offline   Reply With Quote
Old 06-15-2009, 09:41 PM   #6
madaca
madaca's Avatar
Hey Royo, when you say 2 lbs on disk and 10 or more on drums are you referring to foot pounds? What is the best way to measure that?
Grandpas truck, my dream.
This is my truck. There are many trucks like it but this one is mine.
65 Chevy C10 Fleetside
madaca is offline   Reply With Quote
Old 06-15-2009, 10:58 PM   #7
cajundragger
I think he is referring to residual line pressure.
Old 06-15-2009, 11:01 PM   #8
madaca
madaca's Avatar
oh ok. I thought he was talking about the amount of drag you should have when adjusting brakes.
