Old 06-14-2009, 10:10 PM   #1
AJs72K5
AJs72K5's Avatar
BBC 454 .030 over short block
Complete BBC 454 bored .030 over short block
4 bolt main, cast crank, TRW Forged pistons (13.8cc dome), Seal Power Rings, TRW rod bearings, TRW main bearings, TRW cam bearings.
Block casting# 3999389:
3999289....454.......71-79...2 or 4 bolt, some "CE" replacement blocks had four bolt main caps
Was running when when pulled from the truck. Freeze plugs have been removed. Needs a thrust wear plate for behind the timing chain cam sproket. PO left the plate off and the sprocket dug into the block a bit. Easy fix, I'm told.
Selling because I'm building a new motor. I have the build sheet for the motor and will include with the sale. $500.
Casting#
4 bolt main
Pistons and lifter valley
Piston part#
Area worn by timing chain sprocket
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 06-17-2009, 11:10 PM   #2
AJs72K5
AJs72K5's Avatar
Re: BBC 454 .030 over short block
Bump. Talked to some guys that know more about what these are worth than I do. Dropping the price to $400.
- AJ
Old 06-19-2009, 10:53 PM   #3
AJs72K5
AJs72K5's Avatar
Bump. Short block has less than 10K miles on it.
- AJ
Old 06-28-2009, 01:29 PM   #4
AJs72K5
AJs72K5's Avatar
sold
- AJ
