![]() Join Date: Feb 2009
Does anyone know or have pics of how the factory am/fm radio mounts in our trucks to the speaker bracket? I have am radios to compare but the am/fm does not have the same little tab coming off for the support bracket.
Thanks in advance! |
The Red Menace
Re: AM/FM radio mounting
I've never installed an AM/FM, but looking at at least on example on the bay, it looks like they should have the same or similar mounting tab on the back. They use the same speaker so I would think the mounting would be the same.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
Identical to the factory am.
Solve the problem and go with a customer auto sound stereo with a dual voice coil speaker.
If your AM/FM does not have that tab like the AM, it must be out of a van.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Moderator
![]() Join Date: May 2007
They mount identically. Take one of the tabs from an AM radio and put it on the AM/FM. As stated previously, the radio is probably out of a van. If the antenna mount is angled on the bottom, and the Delco print is in block letters on the lens it is from a van. The station number font is also slightly different. No biggie, they have the same guts. I actually prefer the van AM/FM because the antenna is easier to plug in if you have an A/C truck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#7 | |
the boat guy
i dont have the rear mount on my am/fm and its holding up just fine.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Gotta be van. Knew someone on hare would know! My antennae hole is angled. Guess I will just fab a bracket. Thanks guys!
