06-15-2009, 10:46 AM | #1 |
brake system question
I'm going to convert 3/4 to 1/2 suspension on my 72 GMC , question about brake booster can i use 3/4 ton brake booster and pro. valves or is all pwr brake setup the same?, my 70 i got has man. brakes don't want those. ( if it helps i will convert front to disc breake set up). thanks ya'll.
06-15-2009, 11:07 AM | #2 |
Just Not Low Enough!
Re: brake system question
you should be able to run the booster, master, and prop valve out of a 3/4t w/o a problem.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
06-15-2009, 11:45 AM | #3 |
Hey thanks for the info , i though so but was'nt sure , makes it alot easer to use what i got insted of adding more to the build. thanks again
