![]() Join Date: Dec 2008
Rear Frame Crossmember ???
I am getting ready to put my Suburban body on a 4x4 cchasis, When I removed the other body I noticed some custom crossmembers and what appears to be the stock crossmember had been moved to make way for a custom gas tank?
My question is if anyone can confirm that this is the stock x-member in another location and what holes it is supposed to be in for a stock location? (I believe it should reside between the rear leaf mounts?) Thnks in advance. |
Re: Rear Frame Crossmember ???
Anyone have a pic of a rear X-member setup? Are Trucks and Suburbans the same?
I don't have a 4x4 or suburban to take pictures of for you. I can post pictures of that same crossmember on my 2wd LWB truck. It's about 12-13" from the back end of the frame.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
I am pretty sure that they are the same, I really appreciate it.
My body and Frame are stored and the city won't let me set it here...I want to locate the x-member in the right spot BEFORE I put the body on it..LOL |
![]() Join Date: Apr 2005
It is the factory crossmember. I might have a picture in my suburban link in my signature below.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Here's the pictures of the one on my truck.
I can take additional pics if you need another angle.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 06-16-2009 at 03:40 PM. |
Thanks a million to both of you, I figured out where it is supposed to be. I am cutting it off and it should be back home in a few hours
