06-15-2009, 12:35 PM | #1 |
Resident Curmudgeon
67 fun "facts" - I found this interesting
"Facts" is in quotes because I didn't anticipate this nor can I be sure the factory did this...but anyway
I'm building a BB/TH400 3/4 ton 2wd using a 67 frame that was originally a 327/TH400 truck with ram assist power steering. So I had to do the usual frame massage to dimple the front frame horn for the 68-up PS box and trim the upper frame rails for the BB tower mounts. I had anticipated having to drill the hole for the BB/TH400 shift linkage bracket as it is different than the small block version. Yet I found the hole already pre-drilled in the frame so that my BB/TH400 shift linkage lined up as per factory specs. The hole looked factory (as much as a hole can look that way ) Now we all know the BB/TH400 did not exist until 68, and this frame is an original Fremont CA 67 frame. 4x4 frames use a similar auto shift bracket, but no auto 4x4's were made until 1970. What gives? sure surprised me. FYI, there were no holes for the tranny crossmember to move back the 1/2 inch or so, I had to drill them
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all Last edited by CPNE; 06-15-2009 at 12:36 PM. |
06-15-2009, 01:02 PM | #2 |
Under Construction
Re: 67 fun "facts" - I found this interesting
hmmm, I am wondering where are the pics of this?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
06-15-2009, 01:20 PM | #3 |
Resident Curmudgeon
I can take some pics of the bracket installed if you need the "whole" story
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
06-15-2009, 10:19 PM | #4 |
its all about the +6 inches
i wonder if the GMC v-6/TH400 used that hole?
06-16-2009, 02:37 AM | #5 |
Good Call Andy
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
06-16-2009, 09:37 AM | #6 |
Resident Curmudgeon
That is the only reasonable possibility, but that means 1 of 2 things: 1. GM engineered the BB/Th400 combo around not having to drill another hole in the frame. 2. Coincidental luck? Also, why wouldn't the holes for the crossmember be there? The relative placement of the tranny would have to be identical in your scenario, unless the frame shifter bracket for the 305V6/th400 compensated for a more forward position. Probably beating a dead horse, just REALLY surprised by this
06-16-2009, 10:17 AM | #7 |
Excellent pun on the "whole" story. Even better was the fact that you did not tell anyone you intentionally made the pun.
-- Tall, Dark and Handsome... Or so my mother says -- There is no fate, but the fate we make. |
06-19-2009, 05:22 PM | #8 |
Resident Curmudgeon
pics
The upper left nut is the hole in question. The hole further to the left and the lower nut are the holes used by the th350 backet
06-19-2009, 05:25 PM | #9 |
Resident Curmudgeon
more pics of the project trailer puller
