Old 06-15-2009, 12:49 PM   #1
redbaron69
redbaron69's Avatar
front suspension question
need a little help here. found a 76 1/2 2wd that owner wants removed. been parked for 5-6 years ran fine when parked , body is about fall off frame RUST ON TOP OF RUST suspension and drivetrain look fine. question is can i use the spindles, steering, power brake booster, prop valve on my 69? it has a 12 bolt rear ,6cyl, th350 trans.its FREE to the taking if i want it, what you all think?
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 06-15-2009, 01:35 PM   #2
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
Re: front suspension question
I'm not sure about the rear end but you can use all the front suspension for a 5 lug conversion.
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 06-15-2009, 01:52 PM   #3
redbaron69
redbaron69's Avatar
not planning on using the rear, gonna check and see what gears are in there. will the spindles work on my a-arms? will brake pedal connect to booster with any problems?
Old 06-15-2009, 02:16 PM   #4
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
http://67-72chevytrucks.com/vboard/s...ad.php?t=13692 This link is in the FAQ section. Tons of info. I'm not sure on the brake rod. Someone will chime in.
Is it Sunday yet???
68 Project
