Old 06-15-2009, 12:54 PM   #1
JesseSimon
Asks alot of questions
JesseSimon's Avatar
First 66 truck, need a little advice..
Guys I picked up an awesome 66 longbed last week in a trade. I've been working on a 69 pickup for a few months now but this came along and I had to jump on it. I was told it is numbers matching, original but I haven't verified that. I'll post pics as soon as I get a chance.
My questions are as follows:
How do you guys feel about the 283 motor? I want to get some balls out of this truck but if it isn't broke I dont want to try to fix it. In other words how much power can you expect from a 283 after a fresh rebuild and maybe a few upgrades? Can it hang with a 350 in terms of performance?
Additionally, the trans has some issues. It will go reverse all day long but I won't go forward. It is a 2 speed powerglide. I have bought a "high performance" rebuild kit to install in it and assume it will be fine once thats done. Are these transmission any good? My experience is all with TH400 and 700R4 transmissions....how does the powerglide perform?
Thanks for your input
MY STABLE:
'66 C10 LWB turning it into a shortbed stepside
'77 LWB (my daily driver).....oh its a FORD ahhhhh!
'07 MAZDA 3 (the wife's ride)
JesseSimon is offline   Reply With Quote
Old 06-15-2009, 02:37 PM   #2
JesseSimon
JesseSimon's Avatar
Re: First 66 truck, need a little advice..
No opinions at all?
MY STABLE:
Old 06-15-2009, 02:58 PM   #3
stevedh76
Shlongbed #20
stevedh76's Avatar
IMHO - The 283 will be a good little runner. I had one in a 66 Chevelle that i had and it ran good. I put in a hot cam that loped and it sounded good. The Powerglides will hold up but you might want something with a OD. I knew some guys that would run one in a dirt track car and it held up to the abuse. Im sure someone else has an opinion but that was my 2 cents worth.
SEMPER FIDELIS - USMC
1962 Chevy C10 LWB StepSide 235/4 speed
1976 GMC Sierra C15 LWB Fleetside 350/350
1999 Acura Integra LS
2008 Vulcan 900 Custom
stevedh76 is offline   Reply With Quote
Old 06-15-2009, 02:58 PM   #4
dreamtruckproject
First the engine: Yes the 283 is a great engine and can be very reliable. It came stock with different power levels depending on what is was going in. Remember this engine came in everything from trucks to corvette. Can it be built to the 250-300hp range and be fun to drive yet still usable in a truck for truck duties? Yes, but it won't compare to a mild 350. That being said, you didn't indicate what kind of power you are looking for. If you are planning for a good cruiser engine then the 283 would be perfect and can even get a little better mileage than a 350 most of the time. If you are looking for more power or tons of torque then I would look at a bigger engine.
As for the Powerglide, it is kinda the same situation. Is it a good trans? Yes but it has it's limits i.e. only 2 speeds. If you plan to keep the truck stock/vintage theme, then I would keep the 283/PG. If looking for a little update then 283/700R4 or T5/NV3500 if wanting a manual trans. For more power 350 or bigger engine. It really just depends on what you are wanting to do with the truck.
63 Chevy short step
dreamtruckproject is offline   Reply With Quote
Old 06-15-2009, 03:02 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
I agree with the other comments. A 283/PG combo is a nice, reliable set-up that will push the truck around no problem with decent mileage to boot. It's probably not going to be a scary drag race......but with a supercharger, ya never know.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-15-2009, 03:06 PM   #6
JesseSimon
JesseSimon's Avatar
DREAMTRUCKPROJECT, thanks for the input. I am not looking to drag race or anything. 250-300 horse would be quite sufficient for my needs. Just want a little pep. As far as the transmission, will the powerglide be okay for taking the truck out on the freeway? Can it hang with 75 miles an hour?
MY STABLE:
Old 06-15-2009, 03:15 PM   #7
stevedh76
Shlongbed #20
stevedh76's Avatar
YES! As my dad used to tell me there where no speed limits back when these came out at least he didnt abide by them anyways. It will scream on the highway. Also it depends on your rear end gears as well to determine what the RPM's will be.
Old 06-15-2009, 03:32 PM   #8
jchav62
1962 C-10
jchav62's Avatar
I agree. It all depends on the rear diff gear ratio. On any non-overdrive tranny, high gear is always 1:1. In my experience, with no overdrive, the best gear ratios to run are 3.42's or 3.08's. If it has 3.73's or 4.11's, it will be screaming at 75mph on the freeway... 3500-4000 rpms.
Good luck with your truck...sounds like a nice one.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-15-2009, 03:35 PM   #9
dreamtruckproject
The trans itself will be fine, but there are other things to consider. You have to remember that the engine/trans/rear axle ratio were set up for the 55MPH speed limit of the day. If you use the 283/PG and stock rear axle ratio, at 75 your engine will really be buzzing with pretty high rpm. That is why I recomended the 700R4 or stick trans with overdrive to get the rpms down. You can swap the rear gears but then give up the "umph" feeling especially when in town or passing on the highway. If you are looking for just a good cruiser, then I would keep the 283 and look for a 700R4 to swap in. Then even with 3.73 rear gears your still keeping the engine in its power range.
The best thing would be for you to pull the rear differential cover and find out what gears you have. Then find a good online rpm calculator to play with to find what your rpms at certain speeds will be. I like to use this one. It is really setup for offroaders but can be used for 2WD stuff too. I like it cause you can do side by side comparisons at different speeds. Let me know if you need help using it.
http://www.grimmjeeper.com/gears.html
63 Chevy short step
Old 06-15-2009, 05:23 PM   #10
stevedh76
Shlongbed #20
stevedh76's Avatar
Like DreamTruckProject said on the OD tranny
Old 06-16-2009, 12:18 AM   #11
Captainfab
60-66 Nut
X3 on the OD tranny and it sounds like you are familar with them as well.
Even though the 283's will handle the RPM's I myself would prefer to keep the RPM's a little lower. Saves wear and tear as well as fuel.
Old 09-08-2009, 01:50 AM   #12
likaroc13
Rollin' Old Skool
just curious what you decided?...i'm debating on whether to keep my Powerglide w/ 327, or switch to 700R4...i already know the rear needs a better gear, but I'll get that when I swap to 5-lug
Old 09-08-2009, 10:16 AM   #13
1964C10
1964C10's Avatar
Btw I think I saw in classic trucks awhile back that there is a company now that makes a "bolt on" OD for the powerglides. It will require getting your driveshaft shortened but it would keep the classic theme if that is what you are looking for.
1964 Fleetside LWB
1995 Yellow Mustang convertible
1996 Camaro Z28
My build thread
Looking for help on completing the Disc Brake Upgrade Reference Thread
If you didn't build it, you don't really own it
1964C10 is offline   Reply With Quote
Old 09-08-2009, 11:04 AM   #14
Chevy Fleetside
Chevy Fleetside's Avatar
After having a TH350 and a TH700R4 in my truck. I will never use anything but the OD tranny. When you get into OD and Lock up the converter and the truck just smooths out on the freeway is like bliss.. Oh and one more thing. Sorry Joe.. I beat you to it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-08-2009, 12:40 PM   #15
MacAttack
283 Drama Queen
MacAttack's Avatar
See? It's not just me that thinks that about Joe.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 09-08-2009, 01:44 PM   #16
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
We all think that about Joe. I'm with everyone else. The 283 is a good motor, but doesnt that the low end power like a 350 does. PG's are really only good for racing now adays. By the time you put money in it to fix it. you already bought a t350 or t400 and have an extra gear. I would go with the OD trans. But if you just want to have the PG you could always look to get a GearVender under/over drive. that would be cool, but cost.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 09-08-2009, 09:39 PM   #17
Eagar1
I thought I saw on a TV show where they used a transfercase to create a budget OD by running it backwards? Any one ever heard of that?
Eagar1 is offline   Reply With Quote
Old 09-08-2009, 10:45 PM   #18
ruffrida2005
I've never seen a transfer case be used as a OD, it doesn't split gears, just splits power to front and back. You might be talking about a GEARVENDOR it attaches to the trans and is a gear splitter. But they aren't for the budget minded. atleast $1300 for a common trans like the 350 or 400. Look them up.
Paul
Old 09-09-2009, 02:37 AM   #19
Eagar1
I think it had to do with the ability to run in HI or LOW transfer, and it was like reversing the cogs on your bicycle, instead of lowering the ratio, it increased it, and I believe they had to change the rearend gearing, but not sure up or down. I was too lazy to look it up, but now I am curious, so I will do a little research.
Old 09-09-2009, 03:07 AM   #20
Eagar1
Well here is one thread that sorta talks about how it could be done, but I don't think it is suited for anything but extreme applications.
http://www.alaska4x4network.com/showthread.php?t=44392
