Old 06-15-2009, 12:57 PM   #1
JesseSimon
Asks alot of questions
JesseSimon's Avatar
'69 rear end 5 bolt conversion ?'s
I am putting disc brakes up front on my '69, 5 lug system from a newer truck. In order to swap out to 5 lug in the rear, will I have to change the rear end or can I just change the axle rods? My truck has rear coil suspension not leaf.
MY STABLE:
'66 C10 LWB turning it into a shortbed stepside
'77 LWB (my daily driver).....oh its a FORD ahhhhh!
'07 MAZDA 3 (the wife's ride)
JesseSimon is offline   Reply With Quote
Old 06-15-2009, 01:08 PM   #2
redbaron69
redbaron69's Avatar
Re: '69 rear end 5 bolt conversion ?'s
some of the experts may correct me here if im wrong, but the 67-70 axle housings are narrower than 71 and up. best bet is to find a 71-72 coil rear to swap. im not sure here either ,but maybe just get some 6 lug rotors from one of the board vendors???
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 06-15-2009, 01:19 PM   #3
JesseSimon
JesseSimon's Avatar
Thanks for the help. Id rather go five lug all around. I had heard myself that the axles on the older trucks were wider.....anyone know how hard its gonna be to find a 71-72 coil spring rear?
MY STABLE:
Old 06-15-2009, 01:36 PM   #4
Shane
Shane's Avatar
i think it's Early Classic that offers axles in 5 x 5" pattern that fit your housing. You may also check with our board vendors and see if they are a re-seller for ECE products.
Shane is offline   Reply With Quote
Old 06-15-2009, 02:02 PM   #5
JesseSimon
JesseSimon's Avatar
Thanks for the tip
MY STABLE:
Old 06-15-2009, 06:05 PM   #6
GMC3
or you can do what i did. take your axles out, take them to a machine shop and have them redrilled for 5 lug and your center hub shaved down. I think it only cost me $60. real cheap, real easy
GMC3 is offline   Reply With Quote
