06-15-2009, 01:35 PM | #1 |
Clutch rod
Where can i find a clutch rod for a '72? Not having any luck, ordered one that was suppose to fit ( wrong ) i've looked at lmc, manes etc.
Thanx ! Any help is appreiciated. |
06-15-2009, 02:40 PM | #2 |
Active Member
Re: Clutch rod
Which rod? Surprised LMC doesn't have it. There's a lot of vendors on this site that may be able to help. Either call them or email them..
06-15-2009, 02:43 PM | #3 |
Re: Clutch rod
I might have the one you need. Is it the one that attaches to the pedal and goes thru the firewall?
06-15-2009, 02:56 PM | #4 |
Re: Clutch rod
That's the one................Price ? It's for the 6 cylinder, I think they are the same for the small block.
06-16-2009, 01:44 AM | #5 |
Re: Clutch rod
Let me dig thru my stash and see if I can find it again.Will get pics up when I do
06-16-2009, 08:28 AM | #6 |
Re: Clutch rod
They are not the same. The z bar, clutch rod through the firewall and the frame bracket are different for a 6 cylinder. If he doesn't have one I just converted mine to a v-8 and I have them.
06-16-2009, 09:43 AM | #7 |
My Carbon Footprint
Re: Clutch rod
Just curious if this is any kind of a conversion? I went from 250 inline 6 to a BBC. Had to relocate my Z bar on the frame and modify the existing rod....Now that I think about it, not even sure I used the stock one.
06-16-2009, 10:06 AM | #8 |
Re: Clutch rod
Here's what all I have:
06-16-2009, 11:01 AM | #9 |
My Carbon Footprint
Re: Clutch rod
I also had to cut and relocate the Z shape of the bell crank. All easy stuff to do!
06-16-2009, 11:05 AM | #10 |
Re: Clutch rod
....not a conversion yet, just got a rod that the end is just about to let go. Going to try and convert to 350tpi & 5 speed out of an '85 z28 when i start the floors etc. In a few weeks.
06-16-2009, 11:07 AM | #11 |
Re: Clutch rod
06-16-2009, 11:41 AM | #12 |
Re: Clutch rod
Is it worth $10 shipped? Does it look like the correct one?
06-16-2009, 01:28 PM | #13 |
Re: Clutch rod
06-20-2009, 09:30 AM | #14 |
Re: Clutch rod
Do you still need the rod?
06-22-2009, 09:37 AM | #15 |
Re: Clutch rod
Yes, i still need it,........just have not had a chance to check if it's the right one or not. Sorry, busy weekend. Also, i had a little accident in the truck tuesday, a shoplifting suspect sorta ran into my windshield and shattered it, he's in the hospital, scary !
I will try and check it out this week, thanx man. |
06-22-2009, 11:26 AM | #16 | |
Re: Clutch rod
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
06-22-2009, 11:56 AM | #17 |
Re: Clutch rod
..........don't know about saving any day, the crackhead will probably sue me!
06-22-2009, 02:43 PM | #18 |
2WD Jimmy
Re: Clutch rod
06-29-2009, 09:20 AM | #19 |
Re: Clutch rod
06-29-2009, 11:13 AM | #20 |
Re: Clutch rod
any way you want to do it is fine. just shoot me your address and I'll get it mailed out asap
06-29-2009, 11:26 AM | #21 |
Re: Clutch rod
06-29-2009, 11:58 AM | #22 |
Re: Clutch rod
I was going to let you have it for the 10 shipped
06-29-2009, 01:05 PM | #23 |
Re: Clutch rod
