Old 06-15-2009, 03:33 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Slappin' More Paint On It!
I feel like I never get anything done on my truck so I have to post whenever I finish a stage of this "never-ending" painting project. Finished the inside of the box on my 50th Anniversary Big Block Longhorn. Now moving on to Phase 3 - Exterior BC/CC.
Yes the wood was painted from the factory so it is going back to stock!
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 06-15-2009, 03:35 PM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Slappin' More Paint On It!
looks sweet Mike...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-15-2009, 03:41 PM   #3
Hart_Rod
Hart_Rod's Avatar
Looks great Mike. When you get a chance can you send me the paint code? One day I plan on repainting my 50th and would like to have this on file. Thanks
R/
Hart_Rod is offline   Reply With Quote
Old 06-15-2009, 05:55 PM   #4
stllookn
stllookn's Avatar
Rob, It does not look nearly as nice as it does in the full resolution pics. The paint is PPG 23048 Anniversary Gold Poly. I always give them the GM code 551 as well. Dodge also used the exact same color and the exact same name for some vehicles. If they mess up and print the wrong name on the label and you don't check it at the counter it can really screw with your mind when you go to mix paint the following morning!!!!! DON'T ASK! There are three numbers that can be printed on the can and invoice but the important number here is 23048!
Old 06-15-2009, 06:08 PM   #5
stllookn
stllookn's Avatar
Hart_Rod, Another note on primer. GM used black primer under the gold and they sprayed the paint really thin. I used grey and it results in much more "pop" to the gold that most people like. If there were two trucks side by side in a truck show, somebody would be getting points deducted for not maintaining the authenticity of the restoration...LOL! You can definitely tell the difference. My Longhorn is a working truck so I don't really give a rip but it is noteworthy if you are trying to do a period correct restoration.
Old 06-15-2009, 09:03 PM   #6
knsmodels
I make Models
knsmodels's Avatar
I really like the painted wood on the bed....that is how I will do it if I ever convert my truck back to wood bed .....
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 06-15-2009, 09:16 PM   #7
stllookn
stllookn's Avatar
Thanks...here is what I painted over (with the date stamp)...it was pretty nice but just not the same color with the black undercoat.
Old 06-15-2009, 10:22 PM   #8
crm318
Alright Alright Alright
crm318's Avatar
I have a quick question for you stllookn. I noticed that your tailgate is covered in bedliner. Do you plan on keeping that way? The reason that i ask is because my whole bed is covered in bedliner and one day i plan on removing it and painting my bed. How do you get the stuff off?
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 06-15-2009, 11:51 PM   #9
stllookn
stllookn's Avatar
Hey...good eye! PO did that...and it WAS a PERFECT tailgate! I was going to leave it but decided to use another tailgate I have that is not coated. I decided to give this one to my friend whose shop I am using. He has a lined bed and it will match his. I really like the bare metal or wood on a restored truck. Mine will have a camper on it so it will NEVER see dirt or rock...I have a trailer for that. If I had a problem bed and a REAL working truck (you just blew my cover) I would line it.
I wish I knew how to remove it...I am thinking I would try a heat gun first. You might want to call Rhino Liner or one of those compaines to see what they have to say. Sorry I can't be of much help.
Old 06-16-2009, 12:55 AM   #10
VA72C10
VA72C10
VA72C10's Avatar
That looks awesome. I like your choice of the extra "pop" with the grey primer. It always amazes me how the color of primer affects the topcoat.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-16-2009, 01:41 AM   #11
breeh
Recovering 67-72 Addict
breeh's Avatar
The truck is looking really good Mike. Once you get that camper shined up and on there you are going to have the coolest camping rig in Washington!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 06-16-2009, 02:23 AM   #12
72armyswbtruck
72armyswbtruck's Avatar
Man, your never ending project just keeps getting closer and closer to the finish.
Awesome restoration
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 06-16-2009, 05:05 AM   #13
OARNGESI
OARNGESI's Avatar
Looks great
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
