Old 06-15-2009, 09:23 PM   #1
chev-obsession
chev-obsession's Avatar
3/4 ton cab v.s 1/2 ton cab??
is there a difference between a 3/4 ton cab and a 1/2 ton cab, like the way they mount to the frame?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 06-15-2009, 09:30 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 3/4 ton cab v.s 1/2 ton cab??
No differences in the cab itself. The frame mounts and rubber cab mounts are different though.
Old 06-15-2009, 09:52 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
only thing is the 2 on the VIN instead of a 1.
Old 06-15-2009, 10:53 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
A little off thread but:
My son and I found out the hard way that the cab mounts are different on a 3/4 ton than on a 1/2ton.
We took a cab off a 3/4 ton and put it on a 1/2 ton frame using the 3/4 ton cab mount stuff.
When we tried to align the front clip we found the gap at the fender to the cab would not work.
One day when I was searching this forum I found out why. The frame brackets on 3/4 ton and 4X4s are lower on the frame allowing for thicker rubber mounts to allow for a smoother cab ride.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-15-2009, 11:05 PM   #5
vegaschevy
this makes me wonder. I bought a cab and was "told" it was from a 1/2 ton. How do I really know?
vegaschevy is offline   Reply With Quote
Old 06-15-2009, 11:32 PM   #6
Longhorn Man
the vin?
Old 06-16-2009, 02:30 AM   #7
72armyswbtruck
72armyswbtruck's Avatar
Andy, such a short answer,
Help another one out. You know he's new
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 06-16-2009, 10:04 AM   #8
vegaschevy
Originally Posted by Longhorn Man View Post
the vin?
I would have figured that out from your previous post. It has no vin plate in it.
Old 06-16-2009, 10:21 AM   #9
Bears63
...just another truck junkie..
Bears63's Avatar
If you have no VIN plate or any numbers to go on, then there is no way to tell and it really won't matter. The actual mounts on a 3/4 ton are different. The cabs are totally identical, the mounting locations are the same.
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 06-16-2009, 10:52 AM   #10
vegaschevy
thats what I wanted to know. Thank you.
Old 06-16-2009, 06:07 PM   #11
Longhorn Man
i figured I'd be a smart ass, since keven already answered the exact same question, on this thread, in the first responce.
i'm just sayin.
Old 06-16-2009, 09:52 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Good question, and good answers. I was wondering if I could just buy a set of cab mounts for a 1/2 ton for my 3/4 ton truck....since the 3/4 ton mounts cost twice as much. Now I know that I cannot do that and will have to buy the 3/4 ton ones
leddzepp is offline   Reply With Quote
Old 06-17-2009, 02:38 AM   #13
chev-obsession
so baisically if you have a 3/4 ton cab, then you use the 3/4 cab mounts if you were to put it on a 1/2 ton frame?
1965 c/10 swb
1969 c/10 lwb
Old 06-17-2009, 02:41 AM   #14
El Jay
Gone to greener pastures
I think you may have it backward.
Use the mounts that go with the frame.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-17-2009, 07:11 AM   #15
Bears63
Bears63's Avatar
You are overcomplicating this. El Jay has it right, you just use the mounts that are on the frame. The cab doesn't care if the chassis is 1/2 or 3/4 ton, it will sit there, bolt up, and look pretty either way. In a nutshell, don't mess with the mounts, just slap the cab on.
Mike "Bear" Shea
Old 06-17-2009, 12:22 PM   #16
mrein3
mrein3's Avatar
Well I wouldn't say don't mess with the mounts. If you have the cab swinging in the air by a strap, that is the perfect time to mess with the mounts. Throw away the 40 year old factory ones and replace them with a new set from a supplier. Then you don't have to worry about the cab and bed body lines not lining up for another 20-40 years.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-17-2009, 03:25 PM   #17
Figment412
Neither the 3/4 or 1/2 would work on my truck so we had to come up with a custom setup. We ended up with a 2" body lift.
Save your money and do it right the first time.
1968 GMC short bed
1972 Cab
74 SB Chevy running gear
Figment412 is offline   Reply With Quote
Old 06-17-2009, 03:31 PM   #18
69GMCLonghorn
69GMCLonghorn's Avatar
Slight tangent on the same thread:
My cab mounts are there, but severely cracked and dried out. I'll also add that I have a very BOUNCY 1-Ton. Will I actually notice a ride difference if I replace the mounts? Or will it just be money down the tubes?
69GMCLonghorn is offline   Reply With Quote
Old 06-17-2009, 04:44 PM   #19
Bears63
Bears63's Avatar
When I refer to mounts, I am referring to the metal brackets riveted to the frame. The rubber portion is definitely something to be replaced.
Yes, you will notice a ride difference. Replacing those dried out cushions with some new ones will provide a lot more give than the current ones do.
Mike "Bear" Shea
