Old 06-15-2009, 10:48 PM   #1
Dano69c10
Dano69c10's Avatar
1/2 ton to 3/4 ton suspension
I'm converting my 1/2 ton suspension over to 3/4 ton suspension but I have a few questions;
Rear: Are the 1/2 ton and 3/4 ton trailing arms the same?
Front: Is the only difference in front suspensions the upper and lower a-arms and spindles?
Thanx in advance
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 06-15-2009, 11:04 PM   #2
kxnomore
kxnomore's Avatar
Re: 1/2 ton to 3/4 ton suspension
The trailing arms are exactly the same.
On the front, you are right about the A arms, spindles, ball joints, etc. Plus the idler arms are different, too. But it's an easy swap, and I've done it in the reverse direction a few times with no hassles.
The calipers are the same too, I think.
good luck, and take lots of pictures!
kxnomore is offline   Reply With Quote
Old 06-15-2009, 11:16 PM   #3
Hart_Rod
Hart_Rod's Avatar
3/4 ton trailing arms are plated top and bottom. At least the ones I've seen have been.
Hart_Rod is offline   Reply With Quote
Old 06-15-2009, 11:20 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Yep, the trailing arms on my '67 3/4 ton are plated top and bottom.
The are the same for that as best as I can tell.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-15-2009, 11:21 PM   #5
kxnomore
kxnomore's Avatar
Could be. I was thinking the length and bolt patterns and such. I've never actually taken them off a truck. Just swapped rear ends off what was there already. Sorry for the confusion...
Old 06-15-2009, 11:23 PM   #6
Hart_Rod
Hart_Rod's Avatar
They are identical other than the plating that was added to make them stronger.
