Old 06-16-2009, 02:28 AM   #1
ruggirello81
69 truck converting a 350 to a 396
I have a 1969 chevy shortbed c-10 with a 350. I want to put in a 396. What all do I need to switch around. for example coil springs in the front, please help
ruggirello81 is offline   Reply With Quote
Old 06-16-2009, 11:59 AM   #2
70k52wd
Blaze-Air
70k52wd's Avatar
Re: 69 truck converting a 350 to a 396
I'm interested as well.
From what I know, and it's not much. You will need the motor stands, and motor mounts. You'll move your trans cross member back for the t-400 trans, you'll probably need the t-400 trans mount as well. I think you'll need a high hump trans floor pan as well. If your going for a stock cooling system, you'll need a BB radiator and fan shroud. Depends on what your accessories are, but you'll need alt , p/s brackets. You'll need pulleys from big block, or a serpentine set up. Exhaust manifolds if your not running headers.
I'm sure there is more, but this is what I have gathered up so far.
Anybody with more info would be appreciated.
70k52wd is offline   Reply With Quote
Old 06-16-2009, 01:25 PM   #3
mclairmo
I have a 396 in my 67 Camaro and a 350 in my 68 C10 and that 396 likes to run hot. Be sure that you are aware of this tendency and build for it. Big blocks will be harder to cool. Make sure the cooling passages are clear. Some had casting slag in them. I would also suggest running the factory cooling system, such as a new 4 core radiator, factory BB shroud, large factory clutch fan, etc. Also be sure to run the factory pulley set up so that the water pump rotates at the correct speed. Underdrive pulleys will lead to overheating. Make sure your crank pulley is larger than the water pump pulley. Also, make sure to reduce underhood temps, like using cast iron exhaust manifolds or at least ceramic coated headers. Good luck.
mclairmo is offline   Reply With Quote
Old 06-16-2009, 02:21 PM   #4
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
I'm pretty sure you don't need the high hump floor pan. I thinks thats only for manual trannys. Don't think i've ever seen a factory high hump automatic. For the engine stands and mounts there are two different styles. There are the old style for the 67-71 and the 72's. Now the problem i've ran into for the 72 ones is that no auto parts store like napa oreilly's or the such can find the motor mounts themselves. Their computers tell them that gm never put a big block in a 72 truck which we all know is alot of bull and the guy at the auto parts store wanted to argue with me over it. so anyway.They are 72 specific. From what i found they only used them that year and only on the trucks. The only place i've found them so far is LMC. They are $15 a piece.
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 06-16-2009, 02:29 PM   #5
Hart_Rod
Hart_Rod's Avatar
Most big block truck I have seen had a factory high hump. It's not required, the 400 will still fit, but at least from what I have seen they did come that way.
R/
Hart_Rod is offline   Reply With Quote
Old 06-16-2009, 02:36 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
I had a TH400 in my "69 truck with a low hump and it fit fine. Came with a 307/PG stock.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-16-2009, 02:52 PM   #7
my67chevytruck
Under Construction
my67chevytruck's Avatar
R/
My parts truck is a BB auto and it has the highhump as well....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 06-16-2009, 08:58 PM   #8
71 super
71 super's Avatar
you will need bb fan shroud, bb frame stands -68-71 are moe plentiful but the actual mount is extremely expensive, the 72 only stands are really expensive but the mounts are cheap, new fuel pump and line to carb, pulleys for either long water pump or short (short are more expensive and harder to find) correct brackets for accessories- again eithe long or short water pump based. Th 400 mount and move crossmember to rear munting holes, th400 shift bracket or redrill and engineer to make th350 linkage work, different driveshaft. Do not worry about cab hump as th400 will fit w/o problems. Good luck.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-16-2009, 10:12 PM   #9
extd56
extd56's Avatar
On a 69 you will probably need to upgrade to better brakes too and maybe use a 3/4 ton booster. You will also need the gas pedal for the 400 transmission kickdown. The big block alt. and P/S brackets are expensive for the factory short water pump along with the upper and lower pulleys and if you want it to look factory you will need the power steering pump that has the reservior on the fender. The shroud is a lot different too on the big block. The best thing to do is to get a donor with everything that you need.
extd56 is offline   Reply With Quote
Old 06-17-2009, 12:33 AM   #10
Rippin-J
OurLadyofBlessedAccelerat ion
Rippin-J's Avatar
I have a 396 and love it, but why are you looking to convert? not hating on your project, just used to seeing people go the OTHER way!!
Here, call this guy -http://orangecounty.craigslist.org/cto/1215129927.html and you'll have every part you'll need, PLUS you can swap that 350 over to the GMC and sell it. You might even come out even if you're lucky!
_______________________________________________
1968 Chevy C-20 w/ 396
1997 HD Sportster 1200 street tracker
1994 Chevy 1500 Silverado
Rippin-J is offline   Reply With Quote
Old 06-17-2009, 03:32 AM   #11
ruggirello81
I just want to go with a 396. I like the torque.
Old 06-17-2009, 09:02 AM   #12
extd56
extd56's Avatar
The 400 is a electric kickdown that runs off the gas pedal
