Old 06-16-2009, 03:04 AM   #1
BIGJAKE97
BIGJAKE97's Avatar
does anybody have pics of lowered bb c10s with ece front springs?
i put a big block in my short fleet and can't decide wether or not to go with the 1" or 2" front springs? i plan on going with a 6" drop in the rear and have the early classic front 2.5" drop spindles. any pics should make up my mind. thanks jake
67 short fleet
71 blazer 4x4
72 blazer 2wd
76 gmc sierra 3/4t 4x4
62 bel air
01 blazer extreme
member 11,943!
BIGJAKE97 is offline   Reply With Quote
Old 06-16-2009, 06:04 AM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: does anybody have pics of lowered bb c10s with ece front springs?
You could take a look through these......
http://67-72chevytrucks.com/vboard/s...d.php?t=303807
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 06-16-2009, 09:00 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I built this little truck about 5 years ago. It has the ECE 6 inch rear kit, ECE front drop spindles, ECE 2 inch drop springs and a fully dressed big block engine.
Old 06-16-2009, 09:01 AM   #4
Tx Firefighter
Forgot the mention, 275/60 rear tires and 235/60 front tires. I used the smaller tires in the front because I like a raked look, not level stance.
Old 06-16-2009, 09:37 AM   #5
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
You need to remember that tire and wheel inches is going to affect stance and look just as much as springs. I have front tires that are about as big as most people's back tires (275/60/R15)...but most people are not running the size of back tires that I am and they don't look funny on the front at all. There is an overall look to be considered.......also agree with the firefighter: you gotta have a little "rake"!!!
prostreetC-10 is offline   Reply With Quote
Old 06-16-2009, 01:06 PM   #6
coggonobrien
how much drop on this one? thanks
coggonobrien is offline   Reply With Quote
Old 06-16-2009, 01:19 PM   #7
BIGJAKE97
BIGJAKE97's Avatar
oh yeah, i forgot to say that i'm running 255/60/15 in front and 275/60/15 with the stock truck rallies.
eightbanger thanks, i believe i looked through before, but no one really says what drop they have.
tx firefighter that truck looks great.
prostreetc10 how much of a drop is that?
67 short fleet
71 blazer 4x4
72 blazer 2wd
62 bel air
01 blazer extreme
member 11,943!
Old 06-16-2009, 06:00 PM   #8
haulnrat
haulnrat's Avatar
The red and white truck is mine. It has ECE 5" drop rear spring and 1" drop BB front springs with a 2.5" drop spindle. The wheels are 15x10 and 15x8 with 275/60's and 255/60's respectively. It has a fully dressed 454 with factory A/C.
The blue GMC is my dads. His is dropped 4" in the rear with ECE springs. The front has stock BB front springs and 2.5" drop spindles. He is running the same wheel and tire combo as I am. The engine in his is a fully dressed 396 with Hot Rod Air A/C.
I hope this will give you an idea of what you want.
haulnrat is offline   Reply With Quote
Old 06-16-2009, 07:57 PM   #9
prostreetC-10
My Carbon Footprint
I have JDM tubular lower A arms with a 3" stepped spring pocket and 2" BBC springs. The back has 6" springs and just a couple of plates totalling not even an inch. I also have an wedge shim to help with my pinion angle a bit. I guess you would call it around a 5/7 drop. My driveway makes it look like it sets high in the front but it's just the pic. This picture shows the stance and rake a little better even though it's with the smaller back tires (and no motor through the hood!) ;o)
Old 06-16-2009, 08:33 PM   #10
Hart_Rod
Hart_Rod's Avatar
Prostreet - our trucks could almost be twins if you had white on your roof.......
Hart_Rod is offline   Reply With Quote
Old 06-16-2009, 08:35 PM   #11
Security guy
Security guy's Avatar
Here's a few pics of mine. I've got a 402 big block in it. The suspension is all ECE. The front has 2" dropped spindles and 2.5" dropped springs. The rear has 6" dropped springs.
Security guy is offline   Reply With Quote
Old 06-16-2009, 09:10 PM   #12
Boog
laying low
Boog's Avatar
I sure like the way that one sits Security Guy. Tire size?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 06-16-2009, 09:28 PM   #13
prostreetC-10
My Carbon Footprint
No kidding...you have that black, factory primer coming through too!!! I even brush up against mine and the paint comes off!!! lol
Old 06-16-2009, 10:03 PM   #14
Security guy
I've got 255/60 15's all the way around. When the rear tires wear out, I want to get 275/60 15's for the rear. That would give it a little rake to the stance and a little more rubber on the rear. The truck is currently stripped down to just the cab for paint, but hopefully soon, I'll have some new pics. Hope this helps.
