brake conversion
Hey I was wondering if the power disc brakes on a 1974 chevy c10 could be converted over to a 1969 chevy c10 that has drum brakes?
Re: brake conversion
Does any body know?
![]() Join Date: Apr 2005
It will work. The best way (and easiest way) to do it is remove the entire front crossmember from the donor truck. You will also need the master cylinder, power booster and proportioning valve.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Thanks I appreciate your help!
I am a Referee of life.
Welcome Rodney! You can search the FAQ's section for related stuff.There will be way more info than you need but you should find a write up on exactly this swap.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Hey the 69 has only two brake lines coming off the valve proportioner one for the front and one for the back. And the 74 has four lines coming off the valve proportioner for each wheel. Can I use the valve that is on the 69 or do I have to use the one off the 74 and run four lines to each wheel?
Hey I searched the faq's but I didn't find anything that would help
You should definitely not use the 69 valve. Not sure how to adapt the 74 to your application. You could use one from a 71-72 or an aftermarket disc/drum.
#9 | |
Next project: 1970 K10
http://67-72chevytrucks.com/vboard/s...d.php?t=209956 http://67-72chevytrucks.com/vboard/s...d.php?t=215980 These should answer any of your questions.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 06-17-2009 at 12:36 PM. |
Hey I just now noticed that my 69 has six lugs and the 74 has five. Is there a thread on that conversion process? The other 2 threads on the brake conversion has helped a lot thanks
Specifically what conversion. Take the 74 disc and make them 6-lug or make the rear end 5-lug? LMC, CPP, and ECE all carry bolt on 6-lug front discs and any 71-72 truck rear end will swap into yours.
So I can just buy 6 lug rotors
#13 |
So I can take the 74 disc that are 5 lug and just buy some 6 lug rotors from a parts store?
#14 |
Do I just tell them that its for a 74 with 6 lugs
#15 |
I don't know of any parts stores that carry them. Strictly specialty aftermarket:
http://www.earlyclassic.com/catalog.aspx?ProductId=205 http://www.classicperform.com/Store/...ruck/CP4R5.htm http://www.lmctruck.com part # 34-3223 DISC BRAKE ROTOR |
#16 |
Here is what I am doing to have more pics if it helps
#17 |
cpp has the 6 rotors that will work with the 74 parts its the same rotor just 6 lug instead of 5
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
#18 |
Is cpp classic performance parts
#19 |
