Old 01-03-2003, 11:36 AM   #1
Reumster
L.E.D. Freak
Reumster's Avatar
Rear Disk brake kits? Which one?
Ok how many people have rear disk brakes and which ones? How hard of install? Direct bolt on? Performance? Looks?
I seen a Wilwood kit in Summit for 12 bolt for 620.00. Is this kit good?
Specializing in Custom L.E.D. inserts.
http://www.ccled.com/
Contact me @ blazer2wd1972@hotmail.com
(406)675-8082
or Joel @ jmcwaters@eps-corp.net
1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL
Reumster is offline   Reply With Quote
Old 01-03-2003, 12:09 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Reumster, I will tell you what I have been told about rear disc brakes as I wanted to install a kit on my truck at one time. I the folks at Chevy Duty, Early Classics and my local 67-72 collector guy all tell me that the rear disc on 2wd c10's was not the way to go. It seems that even with different proportioning valves they could never get the brakes to work correctly. The would either lock up or put all the load on the front brakes. The guys at Early Classic strongly recommended not doing it. I was bummed! I know Mudder and a couple of guys have disc on their 4bys with no trouble. So, if you are doing this on a 4wd that would probably work. Just the .02 I have heard and I don't want to rain on your parade. If you do go ahead and do the switch let me know how it turns out.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 01-03-2003, 12:44 PM   #3
jmil1974
Ain't we cute?
jmil1974's Avatar
I've heard the same thing about the rear disc. I'd go with the praisedyno pads and springs on the rear and call it a day. You could do their drums too if you do a lot of heavy loads/towing. I know I'll be doing praise pads and shoes as soon as my first set of pads wears out.
69 C10 2WD LWB Fleet 350/350 power front disc conversion (6 lug disc kit from gmcpauls) and new engine, PS, A/C, fresh fluids, SHE DRIVES!
FOR SALE $3900
jmil1974 is offline   Reply With Quote
Old 01-03-2003, 12:51 PM   #4
crazy longhorn
Fabricate till you "puke"
I also agree on the rear disc, the @ss end of these trucks are too light. On my longhorn, with disc front/drum rear, If I lock up the brakes......the rears lock first. I had also looked at the rear disc,they look slick as h*ll........but dont really need them. CrazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-03-2003, 01:38 PM   #5
70c10
67-72 Addict!
70c10's Avatar
A few members here have used the disc setup from a 79' Lincoln Mark 5, they have 9" rear with discs AND Chevy 5 lug 5" bolt pattern!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-03-2003, 01:51 PM   #6
nate68
that's the setup that i have. stainless steel brakes make a kit for the rear. i was looking at getting their force 10 for the front but they're pretty expensive and you have to run 17" wheels i think.
crazy longhorn: you should install an adjustable proportioning valve to solve your rear locking up first problem.
the thing with rear disc is that your front brakes need to be better than the rear. better calipers/pads/rotors, etc. should be used. there's debate on if slotted/cross drilled rotors are actually better or not.
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 01-03-2003, 02:02 PM   #7
crazy longhorn
Nate68, an adjustable valvemay be the ticket,as that old truck is a looong booger! i have moved some weight back(battery to the rear, eng setback on I6 stands), & also plan to move the fuel tank to the rear to help......it has serious traction issues too! How do the Ford brakes work for you?
Old 01-03-2003, 09:40 PM   #8
nate68
i have a fuel cell in the back, engine is in 6cyl location, the 9" is a heavy mofo, a lot heavier than the 12 bolt that was in there. i'm running larger tires in the back than the front.
Old 01-03-2003, 10:27 PM   #9
lux hauler
Psycho-billy Member
lux hauler's Avatar
Anybody ever used Master Power Brakes?
I see they have a rear disk set-up for a 12 bolt.
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 01-03-2003, 11:00 PM   #10
slam33
slam33's Avatar
I have mine all planned out, Eldo 12 inch rears, adjustable prop valve and NO power. Rear discs need to be adjusted to 30%. They lighter, less fade, and give better feed back. There not bad on the bank account either.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 01-04-2003, 02:21 AM   #11
Reumster
L.E.D. Freak
Reumster's Avatar
Yeah I heard that the Early Classic kit was a nightmare. But I still think with a good quality kit, and most likely a adjustable valve they'ed be the ticket. Drums just don't have anyplace on a truck with big wheels. And I plan on 20's soon.
(406)675-8082
Old 01-04-2003, 10:16 AM   #12
fleetimus
fleetimus's Avatar
rear disc
I have been running the Lincoln rear end for a couple of years. No problems at all. I have the corvette style master and the stock 75 c-10 proportioning valve. The front brakes are 75 c-10.
68 Chevy l/b, 4 whl disc in the foothills of No Calif
fleetimus is offline   Reply With Quote
Old 01-05-2003, 02:39 AM   #13
Growdon
rear disks
I installed rear disks on my 72 Blazer 4X4. I used the kit from TSM. The kit was easy to install after I got all the parts together. Steve Chin had a detailed description of the installation on his website that included ordering information for e-brake cables etc.
Growdon is offline   Reply With Quote
Old 01-05-2003, 03:14 AM   #14
Reumster
L.E.D. Freak
Reumster's Avatar
Growdon
What is the web site? You have pictures? How much for the kit?
(406)675-8082
Old 01-06-2003, 02:42 PM   #15
nate68
i am using a 82 1/2 ton proportioning valve (i did the front suspension swap) 75 or 76 corvette master cylinder, 67-72 3/4 ton booster and wilwood adjustable proportioning valve.
Old 01-20-2003, 05:32 PM   #16
Frank_Zeller
Frank_Zeller's Avatar
Found the Steve Chin rear dics brake link.
http://home.pacbell.net/bigiron/Arti...rRearDisc.html
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 01-20-2003, 06:02 PM   #17
Reumster
L.E.D. Freak
Reumster's Avatar
Question
Man that looks like alot of time rounding up parts!LOL
I'd still like to see if anyone uses the Wilwood kit in Summit? I could have sworn that I seen a guy with them on this board?
Isn't the kit from Early use the Caddy stuff?
(406)675-8082
Old 01-21-2003, 01:16 AM   #18
casey
casey's Avatar
Over my head!! I'll stick with the drums for now
casey is offline   Reply With Quote
