06-16-2009, 01:15 PM | #1 |
flip kit rear shocks
I just puchased a 77 with rear flip kit relocating the springs under the axle without c notch. It appears to have stock rear shocks and rides horrible. Would shorter shocks make this better or would I need longer shocks?
06-16-2009, 01:45 PM | #2 |
Re: flip kit rear shocks
you will need shorter shocks. I have the nitro2 drop shocks on my '74 with 6 in. Drop in the back, it also has a flip kit. Also make sure that the rear end is not bottomed out on the bump stop bracket.
06-16-2009, 01:52 PM | #3 |
6.0 powered square
you could always get shock extenders and use factory replacement shocks
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 06-16-2009 at 01:52 PM. |
06-16-2009, 03:37 PM | #4 |
thanks guys, It also has drop springs in front, The guy said 4" springs but I do not think they make that much drop just with springs. I measured from ground to bottom of fender and it was 28inches. Shorter shocks there also?
06-16-2009, 08:21 PM | #5 |
6.0 powered square
do you have a big block and/or are tires shorter than 29"a
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
06-16-2009, 11:01 PM | #6 |
small block. Tires are p275 60's
