Old 06-16-2009, 09:06 PM   #1
DADS71
DADS71's Avatar
do I add power brakes or not if so how?
Just bought 71 cheyenne 30600 original miles from old man in kentucky super solid has alot of options but not power brakes going to spruce up. I have 3 other 71 and 72s garage full. Thinking about adding power brakes what beside buying brake booster and mounting to fire wall and installing master cylinder on that do you have to do? Or do you think I should just leave every thing totally original It still has the original wheel covers.
DADS71 is offline   Reply With Quote
Old 06-16-2009, 10:06 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: do I add power brakes or not if so how?
if u wanna convert to pb, i think its great i did and dont regret it
u need booster,and rod from booster to brake pedel from a power brake truck
you'll need to adjust brakelite, simple but a pita
and run a big vacum line for the pb
any more ? just ask
theres a write up in the faq
John
1999 Toyota Tacoma 4x4
Old 06-16-2009, 10:25 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
That low miles and that original makes for a rare truck.I don't think I would add the PB unless I was keeping it.A hard core restoration freak may want it and adding PB may make it less desireable to someone like that.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-17-2009, 12:50 AM   #4
Jim_PA
I don't think it's necessary unless you have very weak legs.
Jim_PA is offline   Reply With Quote
Old 06-17-2009, 06:06 AM   #5
DADS71
DADS71's Avatar
Thanks for your replys. I think panel deland is thinkin right.
Old 06-17-2009, 08:07 AM   #6
big_al_71
big_al_71's Avatar
I agree with this quote I left mine without power brakes I just love the simple clean look of it..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 06-17-2009, 08:18 AM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Don't mean to divert from the original post.
Hey big al... did you notice any changes in the braking when you added the larger dia. wheels in
terms of the stopping power of a manually based system?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-17-2009, 08:28 AM   #8
big_al_71
big_al_71's Avatar
Hey Nate
We redid the complete brake system new hoses, lines, wheel cylinders, manual master cylinder, prop valeve, rebuilt the calipers. The truck stops very good even with the big motor and big wheels. It does not stop on a dime like my 4 wheel disc el camino did but it stops nicely and once you get used to the pedal it is all good. I am still going to do four wheel disc (willwood or Baers) with new air ride in the near future.I only drive my truck on the weekends here and there so it was not big deal.
Old 06-17-2009, 08:39 AM   #9
WorkinLonghorn
WorkinLonghorn's Avatar
Dads71, It's early here still,and I need to see a picture of that original 30K truck before I can make up my mind,but I tend to agree with PanelDeland.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 06-17-2009, 12:15 PM   #10
Jim_PA
I went from 15" aluminum to 15" rally's (+16lbs on each wheel) there was a very noticeable difference in braking. It only took a few drives to get used to it.
Old 06-17-2009, 01:39 PM   #11
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the information big al and Jim PA!
I personally don't see the need to upgrade w/ a power booster, but that is my own opinion. If I were to drive it daily I would consider upgrading the system.
-Nate
Old 06-17-2009, 01:53 PM   #12
Blue71LWB
Blue71LWB's Avatar
I would add the PB. I think overall your average joe would want PB. Also, I don't think it would hurt the value any. If someone wanted to return it to stock, it would take no time flat.
Working on my first 1,000 post.
I'm sure I'll get there before this project is over .
Blue71LWB is offline   Reply With Quote
Old 06-17-2009, 03:12 PM   #13
Stock72c10
classic=of recognized value
Stock72c10's Avatar
I don't think you will get enough money back out of it to cover the conversion and time to add PBs. If your goal is to flip it spend you time on wax, Armor-All and elbow grease, that will pay off better.
Stock72c10 is offline   Reply With Quote
Old 06-17-2009, 07:19 PM   #14
10pointgmc
10pointgmc's Avatar
I always like the manual brakes they work good and less can go wrong with them
10pointgmc is offline   Reply With Quote
Old 06-17-2009, 11:55 PM   #15
DADS71
DADS71's Avatar
Thanks all for your replys I picked truck up today after work the old man hasent washed it in a while I took pics of him signing over title and also pics of him in front of his old truck pretty cool evening. I cant believe this thing only has 30912 miles on it I was a little off when I said 30600 but I havent seen a 71 with that low of mileage before. On the manual brakes my other trucks have power brakes this manuel brake truck seems weird I push down and its real hard get some squeeks out of peddle is that norm? I spent 4 hours washing and cleaning interior took buffing pad and polishing compound to passenger side and waxed just to see what would happen it buffed and waxed great I think I got 1 of a kind just wish it was a short box if somebody could walk me through steps of posting pics I would love to do that just not that good at computers. Thanks again
Old 06-18-2009, 12:30 AM   #16
PHAT TONY
PHAT TONY's Avatar
I added power booster to my '69 with drums on all 4's; didn't change the pedal, didn't un-cork a line, took about an hour!
PHAT TONY is offline   Reply With Quote
Old 06-18-2009, 10:58 AM   #17
danw210
69 K20
OK we are all waiting to see those pictures now!
danw210 is offline   Reply With Quote
Old 06-19-2009, 11:40 PM   #18
DADS71
DADS71's Avatar
I still dont know how to post pics if I did you guys would probably be sick of me within a week.
Old 06-21-2009, 09:04 AM   #19
ol Curt
Junior Member
ol Curt's Avatar
Guys, tell him if he'll get pics to his old friend Bob, he'll post them for him!!
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 06-21-2009, 12:00 PM   #20
ol Curt
Junior Member
ol Curt's Avatar
Old 06-21-2009, 12:19 PM   #21
DADS71
DADS71's Avatar
Pics of engine
Old 06-21-2009, 12:25 PM   #22
ol Curt
Junior Member
ol Curt's Avatar
ol curts
Old 06-21-2009, 03:34 PM   #23
DADS71
DADS71's Avatar
My blue 71...pic test!!
Old 06-24-2009, 08:19 PM   #24
ol Curt
Junior Member
ol Curt's Avatar
Hmmmm....no pics of that new custom air cleaner yet!!
