Old 06-16-2009, 10:15 PM   #1
seeker
bench seat swap
i have a 67 1 ton flatbed i want to change out the bench seat for a 88 though 98 60/40 bench. Has anyone done this ? does it bolt right up or did you have to modifiy?
seeker is offline   Reply With Quote
Old 06-16-2009, 10:40 PM   #2
KMACD71
KMACD71's Avatar
Re: bench seat swap
Mine is not a 60/40 split, but its a bench seat from a 91 .The front holes lined up but I had to drill new 2 new holes for the back bolts.
KMACD71 is offline   Reply With Quote
Old 06-16-2009, 10:42 PM   #3
seeker
Re: bench seat swap
Thanks I appreciate the info.
Old 06-17-2009, 04:38 AM   #4
NWD02
Re: bench seat swap
Here's mine out of a 95 tahoe... i've done some mods to it. I actually set the passenger side in it tonight and noticed the front holes will line up on each side but the back and all the center bolts will have to be drilled.
NWD02 is offline   Reply With Quote
Old 06-17-2009, 05:07 AM   #5
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Re: bench seat swap
Those seats look good how about a picture after they are installed...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 06-17-2009, 11:55 AM   #6
67c-10Texas
Re: bench seat swap
is that a second row seat or a front?
did you use 67-72 brackets - i would love more info in these i have a second row and it looks similiar out of a 99 burb
67c-10Texas is offline   Reply With Quote
Old 06-17-2009, 12:49 PM   #7
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: bench seat swap
The newer bench should clear up some legroom for ya too. Great for us taller fellas.
--Josh
Old 06-19-2009, 06:18 PM   #8
NWD02
Re: bench seat swap
It's a front seat. I haven't installed it yet. I'm waiting to do all the wiring then I'll install it. I went to a junk yard and cut out the wiring I need to wire in with my wiring.
