06-16-2009, 10:35 PM | #1 |
dropping it
i have a 1969 GMC c2500 and i am thinking about droping it but i am on a bugdet are there any cheap ways of droppin her down a couple inches?
thanks |
06-16-2009, 10:39 PM | #2 |
Happy to be here
Re: droping it
How cheap? You can cut the front coils. Is the rear coil or leaf? If it's coil you can use a block. If it's leaf a lowering shackle will do it.
06-16-2009, 10:42 PM | #3 |
Re: droping it
as cheap as possible, i just got out of school. the rear is a leaf spring set up. where could i get a drop schakle
06-16-2009, 10:44 PM | #4 |
Happy to be here
Re: droping it
You can pull your front springs and cut a coil off. Don't heat them, or use excessive heat to cut them. I cut off wheel is best.
Try the forum vendors for lowering shackles.
06-16-2009, 10:46 PM | #5 |
Re: droping it
thanks
06-17-2009, 09:50 AM | #6 |
Re: droping it
summit has shackles cheap and if you cut the spring your going to run into issues because your changing the spring rate of the coil so when you cut the coil your going to get more body roll and your cornering is going to go to hell summit also has drop springs cheap your best bet would be to get thier stuff if your on a budget but in my opinion i would never ever cut a coil.
06-17-2009, 10:43 AM | #7 |
Re: droping it
if you wanted to do it really cheap cut the coils up front and you can mono leaf the back. it wont ride very good but its pretty much free.
Take it easy, Jonathan
18 and workin' on the first build ('69 C10) 2002 Chevy Silverado REG cab, Short bed, 5.3 V8: Murdered. Club: B-Low Average keepin' it real and low |
06-17-2009, 12:12 PM | #8 |
Re: droping it
the only problem with mono leafing is axle wrap if you get on the gas to hard your liable to snap the leaf then your up poop creek
06-17-2009, 12:51 PM | #9 |
Laid Lo
Re: droping it
I take it you aren't hauling things with this truck?
I would not mono leaf it either. You can take out a couple of leaves for an inch or two but I would want at least 2 leaves and you'll need to drive with a light right foot if you do that. An axle flip kit at POL is like $110 That'll get you 4-5 inches out back with all your spring pack intact. Cut 1 coil. It's not a big deal. Really it's not. It'll be stiffer, but if you cut no more than 1 coil it won't beat you up. Use a cut off wheel not a torch. Good luck.
Semper Fi, Jeff '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
06-17-2009, 10:20 PM | #10 |
Re: droping it
where can you get the axle flip kit? or what is the price for a complete set up to bag it? can you keep it under 600? or at least close
06-17-2009, 11:21 PM | #11 | |
Happy to be here
Re: droping it
I agree that the "best" solution is to purchase a set of lowering springs, but that is not the "cheapest" way.
06-17-2009, 11:23 PM | #12 |
Happy to be here
Re: droping it
Please do not recommend something that is not safe. No one should ever run a mono leaf unless it was a spring made specifically for an intended application.
06-17-2009, 11:55 PM | #13 | |
Laid Lo
Re: droping it
As for bags you could buy a bracket setup for the front $60 from ***************** then buy 2 bags and a set of sharader valves and the front would be done. It'll basically be a static drop since you'll have to hit a gas station but you can always upgrade to switches and compressor, tank etc as you get funds. You probably can't bag the leaf rear for very cheap at all. You'll need a 4 link to keep the axle on, plus bags, brackets etc. The cheapest 4 links are weld in and $3-400 or so.
06-18-2009, 12:09 AM | #14 |
Re: droping it
i guess that isnt to bad maybe the air set up will come later. but i will definatly take a look at the axle flip and some drop coils. it was brought up earlier that some ways maybe cheaper but i would like it to be safe, and occasionaly the right foot gets heavy. but thank all of you for your imput
06-18-2009, 09:36 AM | #15 |
Re: droping it
I heard some where autozone had some cheap drop shackles.
Adam M STX Designs Motorcycles | Choppers | Hotrods |
06-18-2009, 11:33 AM | #16 |
Re: droping it
i have one.. wont cost a thing.......let air out of tires....and you won't have to buy gas saving even more..!! that's what i did with mine..!!!!
06-18-2009, 04:35 PM | #17 |
Re: dropping it
There's one in every crowd ...
