Old 01-03-2003, 01:21 PM   #1
smithjp1
smithjp1's Avatar
Power Steering HELP
I need to know
Will a power steering box off of a 74 chevy HD work on my
68 chevy 4x4 (I have 4 bolt patern from a 67 2wd frame horn)
I already bought one, they had 1/2 day at the Junk yard, please say Yes, if not I guess I will get over it
smithjp1 is offline   Reply With Quote
Old 01-03-2003, 03:57 PM   #2
Pont
I need another Barley Pop
Pont's Avatar
I'm running a power steering box off a 77 Chevy on my 67 Chevy 4x4. I had to make some 1/2" spacers to space the box away from the frame because of the buldge on the side of the steering box. The other way to do this is to heat and massage an indentation into the frame so that buldge will clear. I have even seen a 1/2" thick aluminum plate used to space the box away from the frame, with a cut-out for the buldge. It will fit and can be done but it will probably require some minor modifications. Well worth the effort in my opinion.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 01-03-2003, 04:58 PM   #3
smithjp1
smithjp1's Avatar
Is the steering box you have off a 2wd or a 4wd
It seemed to fit fine when I matched it to the frame, I have a 67 2wd frame horn on my 68 4wd
Thanks for the response
