06-17-2009, 12:09 AM | #1 |
Sunburst C10!!!
spindles
is there any way i can put passenger car spindles rotors and calipers on my 1980 c10 frontend on my 64 c10 pickup
im wanting to do this so i can have 5 on 4 3/4 bolt pattern instead of 5 on 5
Gage 1967 C10 Shortbed Stepside |
06-17-2009, 12:20 AM | #2 |
Re: spindles
We just have the rotors re-drilled to the 5x4.75 bolt pattern. You may also have to turn down the nose-cone on the rotor if running a car wheel.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
06-17-2009, 12:27 AM | #3 |
Sunburst C10!!!
Re: spindles
how much do you charge to redrill the rotor
but i really wanted some aftermarket brakes like aerospace or wilwood
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 06-17-2009 at 12:28 AM. |
06-17-2009, 12:32 AM | #4 | |
Re: spindles
I was having a machine shop re-drill them and turn the nose cone down... $50.
06-17-2009, 12:34 AM | #5 | |
Sunburst C10!!!
Re: spindles
so there is no way i could get different ball joints and get the spindles to work maybe off of a chevelle
06-17-2009, 12:40 AM | #6 |
Re: spindles
You may be able to get them to bolt up, but due to the different spindle heights and outer tie rod location of the steering arm, you would be bolting up some suspension and steering headaches as well.
06-17-2009, 12:43 AM | #7 |
Sunburst C10!!!
Re: spindles
alright do you have a link to your brake setup
06-17-2009, 12:54 AM | #8 |
Re: spindles
06-17-2009, 12:57 AM | #9 |
Sunburst C10!!!
Re: spindles
how many pistons are in each caliper
06-17-2009, 02:28 PM | #10 |
Re: spindles
06-17-2009, 04:36 PM | #11 |
Sunburst C10!!!
Re: spindles
so is that 50 a piece or50 for both toget mine redrilled
06-17-2009, 05:12 PM | #12 |
AIRBAGPARTS.COM
Re: spindles
McGaughys makes awesome parts. And they stand behind everything that they manufacture.
Plus those rotors look SEXY as hell...... |
