06-17-2009, 12:24 AM | #1 |
Problem with master cylinder and proportioning valve
I tried to hook up my proportioning valve tonight to my master cylinder and it doesn't fit correctly.
The proportioning valve is a disk-disk unit from CPP I believe the master cylinder is from a 72 3/4 ton (front disk, power brakes). Do I need to get a 1/2 ton master cylinder? The part number is in the one picture. |
06-17-2009, 07:35 AM | #2 |
Re: Problem with master cylinder and proportioning valve
Your MC is from a 3/4 ton truck so the rear reservoir would be plumbed to the front brakes and the front reservoir would be plumbed to the rear brakes.
A 1/2 ton MC is plumbed just opposite so it should fix your problem. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
06-17-2009, 06:53 PM | #3 |
Why is your valve and braket upside down?
06-17-2009, 08:51 PM | #4 |
that's the only way it would hook up......see answer above
I got a new MC, I assume it will hook up correctly |
06-17-2009, 09:35 PM | #5 |
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
06-18-2009, 01:39 PM | #6 |
I got a new 1/2 ton MC and all is good, thanks guys!
