View Poll Results: Which hood and grill to use on my truck painted in turquoise?
60-61 Glass Hood in Turquoise (white 60-61 grill)? 10 45.45%
64-66 Steel Hood in Turquoise (white 64-66 grill)? 12 54.55%
Voters: 22. You may not vote on this poll
Old 06-17-2009, 01:54 AM   #1
Arekusu
Arekusu's Avatar
Old School Hot Rod Truck (1964)
Well, I've waited long enough. Time to contribute to this board. Here is what I've been working on for the past year and a half. Hope you like it.
Here is how I found it and what I first did to it or what I took off of it last March. It was a old farm truck used for moving goats here in New Mexico. I pulled a fur like substance off of just about everything when I started pulling it apart.
Arekusu is offline   Reply With Quote
Old 06-17-2009, 02:02 AM   #2
Arekusu
Arekusu's Avatar
Re: Old School Hot Rod Truck (1964)
Well that was the 292 L6 that was in it. I wanted to keep that thing but gas mialage and lack of parts made me rethink my decision. I had a 64 C-10 before I joined the USAF 5 years ago but never got to do what I wanted to do to it so now was the time. I decided to go with the stock front springs, 2 1/2'' drop spindles up front and 4'' drop springs in the rear. Also at this time I decided to do disk brakes and all new brake lines. Steel braided from the master cylinder and from the upper control arm to the caliper. I had to extend the rod from the booster to the pedal by about 2 or so inches. I went down to the local Albuquerque metal shop and had them make me a $10 par that had the right size holes. (A piece of 1/4 inch flat metal with 2 holes) I used the upper and lower control arms and calipers off of an 85 C-10. New bushings all round and rebuilt calipers from NAPA. (My NAPA guys know me WAY too well now, we joke it's sponsored by them)
Old 06-17-2009, 02:08 AM   #3
Arekusu
Arekusu's Avatar
Well while pulling out the heavy old 4 speed we noticed that the rear diff. was very sloppy. SO I decided to get that rebuilt at the same time I got the T-5 rebuilt. Thinking back on it I would have put the more modern 12 bolt under it or a Ford 9'' but, I just got back from Japan and needed wheels yesterday so I went with what I had, the old 64 diff. One thing I didn't know at the time of getting this diff. rebuilt (but was told by my re builder) is that back in 64, they didn't go by the number of bolts for ordering parts, they went by the size of the diff. Maybe that info might help someone later on...
Old 06-17-2009, 02:12 AM   #4
Arekusu
Arekusu's Avatar
I did some reading on transmissions and opted for the T-5. All my planning at this time was done for keeping the 292 L6 rather than moving to the V8. So the T-5 fitted my needs. It came out of an 80 something S-10. The 4 speed bell housing bolted right up to the T5, and I got to keep my mechanical linkage. I didn't have the time or extra funds at the time to opt for a hydraulic clutch.
Old 06-17-2009, 02:18 AM   #5
Arekusu
Arekusu's Avatar
The pic with the stick of inches represents how much further back the new shifter would have to be from the stock position. I ended up using a modified short throw ford shifter (modified it, didn't know it was for a Ford, thx ebay) and had a custom stick bent up and welded on. I'll take pics if anyone wants them of that. The last 2 pics show how I drove it for 5 months before building and installing the V8. New and matching tries and rims of course.
Old 06-17-2009, 02:19 AM   #6
OARNGESI
OARNGESI's Avatar
Sure has come along way nice work
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 06-17-2009, 02:27 AM   #7
Arekusu
Arekusu's Avatar
Painted engine bay, old 292 L6 and new V8.
V8 = 327 block 40 over, 350 crank,Vortec heads with new behive springs, edelbrock intake, holley 650 spreadbore carb, comp cam 12-235-2 duration at .050 Intake 210 Exhaust 218 Balanced crank, crank aligned to the block. Long tube headers (collectors scrape sometimes with the 2 1/2'' drop in the front when I go in some place with an aggressive angle.)
Old 06-17-2009, 02:33 AM   #8
Arekusu
Arekusu's Avatar
Well I wanted this thing to handle like a sports car as much as possible (lol) so I decided to go with an old 3/4 ton swap bar off of a 80 something Chevy 3/4 ton truck. It bolted right up ( 85 lower control arm used). I removed one of the rivets on the front and the hole spacing was perfect for the mounts. I drilled 2 holes. I tried doing this with the engine in and couldn't get the rivet to come out (even tried an air hammer). I was using a grinder. Maybe all of you with a plasma torch might have better success. Later plans include a rear sway bar. I'll follow up with that one.
Old 06-17-2009, 02:35 AM   #9
Arekusu
Arekusu's Avatar
The engine goes in.
Old 06-17-2009, 02:45 AM   #10
Arekusu
Arekusu's Avatar
The engine went in. I bought a JEGS HEI distrubiter for it. Well I used the old L6 mount holes (mounting the mounts closer to the cab) and the new HEI didn't fit. Well I could have made it fit by beating the firewall, but thats just not cool. So I'm running points still.
About a month ago I got my 60-61 hood in so I decided I'm going to rattle can the truck satin until I can afford a proper paint job. I really don't think it looks that bad. I thought the half and half look was funny. I got tons of looks by people that saw both sides of the truck. But now the font end it totally painted.
Old 06-17-2009, 02:50 AM   #11
Arekusu
Arekusu's Avatar
And the last two are how it currently sits.
The next things on the list of things to do are,
1. finish the rattle can paint
2. Paint and install the camaro rear sway bar with new bushings
3. sound proof the now solid floor pan
4. Get the tilt front end done
Thanks for looking for now. Now that I have started this thread, more to follow in the next 4 months.
Alex
Old 06-17-2009, 03:39 AM   #12
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I like it.
Old 06-17-2009, 07:19 AM   #13
jason65
Registerd User
jason65's Avatar
Looks good.
jason65 is offline   Reply With Quote
Old 06-17-2009, 08:22 AM   #14
joe231
joe231's Avatar
Nice truck!
how do you like the T-5 in there?
CHEVY ONLY
Old 06-17-2009, 08:27 AM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Wow... great progress over the last year. Nice work!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-17-2009, 08:45 AM   #16
4dranch
Shloooooong bed member #2
4dranch's Avatar
Them hoods are so freaking cool looking...Nice work.
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 06-17-2009, 09:37 AM   #17
jchav62
1962 C-10
jchav62's Avatar
Nice work! I like it a lot!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-17-2009, 09:46 AM   #18
TwiggyTheDrummer
Keep It Simple Stupid.. Nope..
TwiggyTheDrummer's Avatar
Looks great man!
1963 GMC SWB Fleetside in Sunburst Orange Metallic
305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust
Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire.Custom Classic Trucks
TwiggyTheDrummer is offline   Reply With Quote
Old 06-17-2009, 10:29 AM   #19
MacAttack
283 Drama Queen
MacAttack's Avatar
Slow down on the pictures - Joe has to be losing it about now.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 06-17-2009, 10:32 AM   #20
TwiggyTheDrummer
Old 06-17-2009, 10:48 AM   #21
Chevy Fleetside
Chevy Fleetside's Avatar
The HEI should fit. These fit with penty of room behind it. I found one on e bay for less money plus a $25 rebate. This would be my 2nd becuase I let the first one go when I sold my sb. I ended up paying $95 for the one I have now. http://www.summitracing.com/parts/MAA-8548201RC/
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-17-2009, 11:02 AM   #22
stevedh76
Shlongbed #20
stevedh76's Avatar
Nice Progress on the truck. I love the hood! Cant wait to see what it looks like when it is done. Ja Ato De. Choto deki Nihongo wakarimasu. I spent 3 years in Okinawa in the Marines. Loved Japan!
SEMPER FIDELIS - USMC
1962 Chevy C10 LWB StepSide 235/4 speed
1976 GMC Sierra C15 LWB Fleetside 350/350
1999 Acura Integra LS
2008 Vulcan 900 Custom
stevedh76 is offline   Reply With Quote
Old 06-17-2009, 01:07 PM   #23
Arekusu
Arekusu's Avatar
Thanks for all the comments so far. The T-5. I love that thing. I'm at 2100 rpm at 70mph on the highway with 373's in the back and 255/60 r15's under it. It also makes mustang killing a little easier with 4th and 5th. The last 2 gears are like the ace up my sleeve.
Old 06-17-2009, 05:27 PM   #24
Corts60
Just here to tinker
Corts60's Avatar
Hell yeah, rattle can the sh*t outta that thing! That's the way my Nova is rolling right now.
I'm glad to see that your going with the earlier front end. It looks much better in my opinion.
Old 06-17-2009, 06:56 PM   #25
monolith
Zero Albedo
monolith's Avatar
I love those early hoods!
Nice color- nice truck!
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
454, bbc, hot rod, moser m9, tko-500
