Old 06-17-2009, 11:24 AM   #1
BossHogg69
motor exploder
BossHogg69's Avatar
SBC Cloyes Timing Set and Aluminum Cover
I have a brand new Cloys Hex-a-Just Timing Set, 9-3145A and a matching polished aluminum 2 pc 'Quick Button' timing cover, 9-225. This is a top of the line billet steel double roller, and the center of the cover comes out so you can degree the cam w/o taking the cover off. I'll throw in a Fel-pro timing cover/water pump gasket too. This setup is for an 85-up factory roller block that uses a cam retainer plate (like a TPI/camaro/vette motor) I was gonna use it on a 383 I was building for my '92 chevy C1500, but I sold the truck and the short block, and have this left over. The timing set was $165 bucks, and the cover was nearly $140 from Summit. I'll take $200 shipped to your door, would like to have payment by PayPal if possible.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
cloyes, roller cam, small block, timing cover, timing set
