05-17-2002, 12:12 PM | #1 |
Power Steering Questions
Will a power steering gearbox from a later (73-87)model truck work on the 67-72 trucks?
05-17-2002, 01:22 PM | #2 |
any will depending on if you are good with fabbign hoses to use the 80-up ones, otherwise stick to 79 and older ones for direct swap 100%
------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 *many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme and 84 SE Firebird T5 3.73 current fleet: -71 C-10 350/CH465/3.07- assembling currently -90 Cavalier/2.2/sky blue, driver #2 -84 Z28 5.0L/700R4/3.73 daily driver #1 -'90 Corsica 3.1L and '82 purple Trans Am- storing *Paint is overrated* © RSS Enterprises 2000 |
05-18-2002, 01:06 PM | #3 |
I replaced my 72 power steering box with a 76 unit. The 76 did have the pitman arm already on it. I used all of the 72 steering column parts. I used the 72 power steering pump and lines. Everything bolted together as if I was using the 72 power steering box. Alignment, as per standard sepcs, drives without any problems. I did add a steering stabilizer unit.
------------------ 72 Cheyenne Super, Fleetside, Shortbed, Original Owner, Special Ordered 350ci/340hp, Auto Trans, 3:70 Posi, Tow Package Northern Calif
72 Cheyenne Super, Fleetside, Shortbed, Original Owner, Special Ordered 350ci/340hp, Auto Trans, 3:70 Posi, Tow Package Northern Calif |
05-18-2002, 01:34 PM | #4 |
up to 87 will work. I put a 85 on mine
------------------ 68GMC SWB Gound-up restoration,350/700R4/??? 2002 3/4 HD for a daily driver. Can't get away from the GMs
68GMC SWB Gound-up restoration,350/700R4/????.... 2002 3/4 HD for a daily driver. Can't get away from the GMs |
05-18-2002, 09:02 PM | #5 |
80 on are metric boxes,& will have an O-ring fitting instead of the old flarenut. I have an 84 Burb box on the longhorn,& it was an easy swap using the hoses for the burb,& replacing the fitting in the pump......but I do have 73 up waterpump,pulleys,ect(the 383 is in 6/250 position for weight transfer). good luck.........69
http://community.webshots.com/user/hotrodhorn |
