Old 06-17-2009, 07:09 PM   #1
Copperman
Copperman's Avatar
Gear Shift Removal
I wanna take the gear shift out of my '70 and shorten it. Its a 4 speed manual on the floor. The service manual says something about a tool and makes no mention of what looks like a pin going through the side. Do I need this tool?
Matt
1970 C10
Copperman is offline   Reply With Quote
Old 06-17-2009, 07:23 PM   #2
VanceH
Loving the Jimmster
VanceH's Avatar
Re: Gear Shift Removal
I have done this twice the last month, the first one i ruined. if you push down on the rounded part, (the shifter comes thru), it will go down just a little and allow you to turn it a quarter turn, then it will lift right out.
VanceH is offline   Reply With Quote
Old 06-18-2009, 10:03 AM   #3
Wrenchbender Ret
You do not need a special tool. Take a pair of Channel lock pliers, press down on the coller & turn it ccounter clockwise about 30 degrees. It should lift right out.
Wrenchbender Ret is offline   Reply With Quote
Old 06-18-2009, 10:13 AM   #4
Copperman
Copperman's Avatar
Turn the collar or the shifter counter clock wise? I assume the installation is just in reverse?
Matt
1970 C10
Old 06-18-2009, 04:08 PM   #5
71 super
71 super's Avatar
Place the shifter in neutral and turn counter clock wise on the bulb that is around the shifter no need to mess with the pin. Should not even need pliars if you use a little wd-40 of similar first.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-18-2009, 04:45 PM   #6
michael bustamante
michael bustamante's Avatar
i could have learned this last week I just unbolted the whole plate on mine >
1967custom
michael bustamante is offline   Reply With Quote
Old 06-19-2009, 12:13 PM   #7
Copperman
Copperman's Avatar
Ok...getting it off was easy...no tools required. But do you have any tips for putting it back on? that spring is one stiff sucker and I cant push it down far enough by hand.
Matt
1970 C10
Old 06-19-2009, 01:05 PM   #8
Copperman
Copperman's Avatar
Actually im starting to suspect the gearshift is not seated far enough into the tranny. When I look down into the opening, I dont see a clear slot for the shifter to seat into. Right in the way is a spring loaded stainless pin on its side. Is this right?
Matt
1970 C10
Old 06-19-2009, 01:20 PM   #9
Copperman
Copperman's Avatar
Ahhh never mind. I got it. The little pin (that I assume is for the reverse gear) was in the way. I pushed it back with a screwdriver and all is good.
Matt
1970 C10
