Old 06-17-2009, 08:26 PM   #1
HvyChevy
HvyChevy's Avatar
Body mounts, help
I have a new body mount kit and I read on here that a 7/16 bolt is used for the core support mount. Is this correct?
(I would think a bigger bolt would go there. The hole is bigger.)
Then does the tallest bushing go under the firewall? The short fat one for the core support? I know all the back bushings are the same, just questioning the front two positions.
Thanks,
some pics: finally coming back together
HvyChevy is offline   Reply With Quote
Old 06-18-2009, 09:30 AM   #2
Burt4x4
Burt4x4's Avatar
Re: Body mounts, help
When I did mine I put in the biggest bolts I could, bigger IS better
I also used nylon lock nuts to keep them from comming loose.
Do NOT over tighten your mounts, you want them nice and snugg but don't pinch or squeeze the mounts too much. They need to flex.
Sorry I don't remember wich mount went were??
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 06-18-2009, 03:38 PM   #3
swyfor5
swyfor5's Avatar
Wow, off topic, but what color is that on your K5? I like it!
swyfor5 is offline   Reply With Quote
Old 06-18-2009, 04:19 PM   #4
drunkbus
New Member
drunkbus's Avatar
The 2 front are 7/16, the 2 front floorpan are 9/16 and the rest are 3/8. I couldn't find 9/16 when I did mine but 5/8 worked fine. I went with poly mounts and the stock length bolts only worked in a few places. I had to get longer bolts for all but 4 spots.
drunkbus is offline   Reply With Quote
Old 06-18-2009, 04:28 PM   #5
70k52wd
Blaze-Air
70k52wd's Avatar
I love it.
70k52wd is offline   Reply With Quote
Old 06-18-2009, 07:02 PM   #6
HvyChevy
HvyChevy's Avatar
Thanks for all the info!!!
I had the front two mounts reversed.
Thanks, the color is 2009 Dodge charger r/t model. Took it out of a Chrysler color chart. It's a metalic so looks great in the sun...
Old 06-19-2009, 05:41 PM   #7
swyfor5
swyfor5's Avatar
Thank's, looks good! Keep us posted!
Old 06-21-2009, 11:20 PM   #8
shiner
shiner's Avatar
Stealing the thread...I'm about to do the same, trying to decide what is better, rubber or the poly. My main concern is I've read the poly squeak after a while, true? Thanks, hopefully I can order them and get it done this Saturday.
shiner is offline   Reply With Quote
Old 06-23-2009, 06:21 AM   #9
vtblazer
vtblazer's Avatar
The stock rubber style is going to ride a bit softer but will flex more when wheeling.
Might be a day late to the party but here's a body mount assembly page.
vtblazer is offline   Reply With Quote
