Old 06-17-2009, 09:40 PM   #1
classic70
classic70's Avatar
3 speed to 4 speed
What is involved in replacing a three on the tree to a 4speed. Is a driveshaft change nessicary? High Hump? Thanks
classic70 is offline   Reply With Quote
Old 06-18-2009, 10:10 PM   #2
classic70
classic70's Avatar
Re: 3 speed to 4 speed
ttt
Old 06-18-2009, 10:12 PM   #3
ZombieWeinerDog
ZombieWeinerDog's Avatar
i want to know also
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 06-18-2009, 10:28 PM   #4
cstm68
cstm68's Avatar
i did this in my 68, i had a 3 speed with a floor shifter, i used a saginaw 4 speed out of a 67 camaro, everything bolted up the same just had to get a new shifter and swap the input bearing cover from the 3 speed to the 4 speed, the one off the car 4 speed is to small for the truck bellhousing. but that was just 4 bolts and some sylicone to re seal it, the drive shaft was the same, i just had the rewire the backup switch, on the 3 speed it is on the steering columb and the 4 speed it had a switch on the trans, that was an easy fix, just splice the wires from the 3 speed switch the the ones on the tranny.
any onter questions just let me know, there are also a few pics in my build.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
