Old 06-17-2009, 10:37 PM   #1
gripnrip
Gripnrip
tachometer mounting
Okay, here is a few pics of my pending projects. A 71 GMC 3/4 ton 4x4, a 67 chev 3/4 longbed stepside 292, 67 chev short step 230. The 71 is getting a tachometer installed and I need some help with the wiring. Hopefully the photos show the wire to the firewall cluster, this wire has two ends, one end has a female fitting and the other has a male fitting. This wiring is factory gm. The other end I am to understand connects to the distributor coil Positive side, which is the positive side. I have connected the distributor coil end of the wire to one side of the coil. The male end of the other end of the wire is attached to where I believe it should be. I am not getting any movement out of the tach. Any help?[IMG][IMG][IMG][IMG][IMG][/IMG][/IMG][/IMG][/IMG][/IMG]
gripnrip is offline   Reply With Quote
Old 06-17-2009, 10:38 PM   #2
gripnrip
Gripnrip
Re: tachometer mounting
Apparently I don't know how to attach a pic. Any advice?
Old 06-17-2009, 10:56 PM   #3
leddzepp
Moderator
leddzepp's Avatar
The brown wire goes to the Neg side of the coil, not the positive. The pink wire goes to a 12v supply on the fuse panel. If you have factory ignition, the neg side should be the side closest to the front of the vehicle. Look closely, they are marked.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 06-18-2009, 01:18 PM   #4
gripnrip
Gripnrip
Photo download attempt #2.http://67-72chevytrucks.com/vboard/a...1&d=1245347252
Old 06-18-2009, 01:20 PM   #5
gripnrip
Gripnrip
The wire I am pointing to in the pic above shows the male lead, the female lead is plugged in.
Old 06-18-2009, 10:00 PM   #6
gripnrip
Gripnrip
Thanks ledzepp, the tach is working now but it seems to be reading way too high. The tach came out of a gmc 6500 farm truck, maybe that has something to do with it reading wrong.
