Old 06-18-2009, 12:04 AM   #1
rickyrqacer
Toasted Dually Club
87 Dually Fuel Gauge
my 87 CC dually sits a long time between uses, it's been 10 months since on the road, although I do start it once a week, yesterday, I started it up and the fuel level arm goes to the 3 o'clock position, the tanks are full, but it's never indicated like that . .. where should I start looking? switching tanks makes no differance ... I need to fix it in the next week, it's racing time ..
Rick
rickyrqacer is offline   Reply With Quote
Old 06-18-2009, 01:07 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: 87 Dually Fuel Gauge
Check your grounds under the dash and also the ground leads at each tank.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 06-19-2009, 02:06 AM   #3
rickyrqacer
Toasted Dually Club
thanks ble ... I did check grounds, still wierd, everything else works on the dash, any other ideas?
Old 06-19-2009, 02:11 AM   #4
77shortybawx
77shortybawx's Avatar
possibly a mouse chewed through the wire that connects the gauge to the sending unit(s).
1977 Chevy c-10 Scottsdale
1978 Chevy Camaro
1979 Mercury Cougar
77shortybawx is offline   Reply With Quote
Old 06-20-2009, 01:04 AM   #5
BLE 'BURBAN
Are you sure your selector valve is functioning? The wiring from the sending units to the gauge runs through there as well.
you might also take a multimeter and check the ohms resistance right at the sending units them selves. G.M. fuel tank sending units run the raange of 0 - 90 ohms full to empty. If you know for sure there is fuel in the tank and the sender is in good working order, then with the multimeter grounded good to the frame touch the positive lead to the sender terminal on the top of the tank and check your resistance.
