06-18-2009, 12:41 AM | #1 |
truck not setting level
i have a problem with my truck i got a 86 c-10 the truck seems to be leaning to one side i posted in the suspension section with no answer Ive looked over my suspension cant really figure it out any input would be appreciated ill post pics of both side of trucks look at the pass side sits higher than drivers side
06-18-2009, 01:15 AM | #2 |
In the Forgotten far North.
Re: truck not setting level
How many miles?
Can't see any differance in those pics. Take a pic from directly in back and the same from the front so we can see how much it's listing to one side. With a tape measure, measure from the ground up to the top of the wheel well opening and post your findings as well.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade Last edited by BLE 'BURBAN; 06-18-2009 at 01:16 AM. |
06-18-2009, 01:46 AM | #3 |
which way is it leaning?
i see a p side fuel tank. how big are you? whe you put the new coils in were the coil ends seated in the same position in both cups? they have a notch they sit in do the leafs have the same amount of layers and layer lengths. springs weaken over time and will settle differently. |
06-18-2009, 06:37 AM | #4 |
You need to get a bigger gf. But seriously, it's very common. People call it the "Chevy Lean". Between the driver and gas tank, the left side springs just seem to get tired. New springs & bushings all around will fix it, not to mention make your truck ride a whole bunch better.
06-18-2009, 07:11 AM | #5 | |
Yes. They used to do that even when new in the factory, although we called it "box lean". About once a year we'd fire up some big experiment to try and fix it (...never did...). I'd just shim (either at the suspension or between the box and frame) until you get it the way you want it. MHO - K PS - sweet truck, btw...
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-18-2009 at 07:13 AM. |
06-18-2009, 11:44 AM | #6 |
Next project: 1970 K10
Nice looking truck!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
06-18-2009, 02:08 PM | #7 |
I have car A.D.D.
I agree. Great truck. If you figure out a great & fairly easy way to fix it, let us know. My thought...before seeing the pictures...was maybe body mounts, but thats not the case based on the fact that the bed sits level to the cab.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
06-18-2009, 04:13 PM | #8 | |
spirit rider66
Location: pahrump, nevada, in the bowels of the Mojave desert
:Chevy: If you don't run your own life,, some one else will. to our vets,, welcome home,, and thank you for your service.:Chevy: |
06-18-2009, 07:44 PM | #9 |
thanks for the input
