anyone running a ford 9" rearend?
I found a 1976 Ford f150 with a 9" rearend to swap into my 77 Chevy. I read that the stepside hotrod is building took a rearend from a 78 ford truck. Anyone know what mods will be needed to install the rearend into my truck? Any advice would be appreciated.
Low & Fast!
Re: anyone running a ford 9" rearend?
The big thing is cutting all your mounts off the 9" and taking yours off and welding them on it. And I think you may have to have a drive shaft make using the 9" ford yoke.
Did I miss anything?
possibly use a conversion u joint from a local drive line shop, that would save a little money over getting the driveline redone for a ford yoke.. but yeah tvblazer78 nailed it..
be a site supporter |
Thanks guys
profeshinaly unimployed
well if u want it too run good better use a gm rear end lmao
"having mud flaps is like asking for a smaller trophy" |
