Old 06-18-2009, 02:15 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
wire
my ground wire doesn't look too great ...alot of the outside rubber is chipped away and is just plan used and abused lol so i was wondering would a 4gauge amp power wire be good enough for my ground
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 06-18-2009, 02:41 PM   #2
dough_boy
dough_boy's Avatar
Re: wire
as long as the wire you are using for ground is the same size or bigger than your positive cable it will work just fine. 4 gauge should be plenty good bro.
dough_boy is offline   Reply With Quote
Old 06-18-2009, 02:43 PM   #3
JohnC
JohnC's Avatar
Re: wire
JohnC is offline   Reply With Quote
Old 06-19-2009, 06:42 AM   #4
East End K5
Re: wire
Ensure your bonding wire from the cab to the engine is good, along with the ground from the battery to the front radiator support.
I feel sorry for people who don't drink....because when they wake up in the morning, that's the best they're gonna feel all day long!---Frank Sinatra RIP
[B]1972 Chevrolet K5 Blazer RIP
1986 GMC Sierra K3500 1TON, Long Box, V8350 RIP
1980 Chevy Silverado C30 Cab and Chassis, 454 TH400HD. RIP
[B] 1995 Chevrolet Tahoe 2D [B]
East End K5 is offline   Reply With Quote
Old 06-23-2009, 02:34 AM   #5
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: wire
It won't hurt for the insulation to be gone on a ground wire.
If it's corroded you should replace it though.
Check you'r pos cable while you're under the hood, the insulation on it could be on it's way out, and with the fuel leaks you have,
you don't want any sparky sparky.
heavychevy79 is offline   Reply With Quote
Old 06-23-2009, 06:25 PM   #6
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Re: wire
Using the cable is fine but what about the Terminal ends?? Pinching the cable under the head of a bolt isn't a permanent fix.
powerdriver 1958 is offline   Reply With Quote
Old 06-23-2009, 09:18 PM   #7
78 Chevyrado
Re: wire
Battery cables should have the ends soldered to the terminals. Remember, Bad connections cause resistance which causes heat, which causes more resistance, which causes more heat, which causes more resistance..... If you can get a voltmeter, use the OHM setting to find out how good your connections are.
78 Chevyrado is offline   Reply With Quote
