Resistor wire removal
What is the easiest way to remove the resistor wire for the ignition? I would like to cut the ends of the 2 yellow wires in the engine compartment and tape them back in the bundle. I would like to remove the feed from the fuse panel first as I don't want any live wires. Do I have the take the fuse panel out to remove the connection, or is there an easier way?
Active Member
![]() Join Date: Jul 2007
Re: Resistor wire removal
I unwound the old electrical tape and added a 12 gauge wire for HEI. I left the resistor wire in the wire bundle (in case I want to go back to points) and just retaped everything back up.
Not that difficult to do. |
When I upgraded my inline 6 to HEI I just cut the wire at the junction block(under hood, at the firewall) leaving about 1 inch then pig-tailed off of that with a new 12g wire.
Works fine, although my truck is not street worthy yet, I do start it once in a while and drive in the back yard. More specific to your question (I hope), I think you can remove the engine side connector with the single bolt, cut the wire. then using needle nose pliers remove the pin completely. Last edited by Kayotic; 06-18-2009 at 04:30 PM. |
member #16
![]() Join Date: Dec 1999
Heres a thread with a how-to by shifty on how to replace resistor wire. Scroll down a ways and it has connector part no.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
