06-18-2009, 03:28 PM | #1 |
pcv valve need
71 c10, 350, hei, eps man, 1406 carb, hedders going on tomorrow,
Is it ok to disgard the pcv and plug the pcv port on the carb or would this cause problems, run better or worse, I dont have emision requirements, looking to get new valve covers and the ones I like dont have a pcv hole |
06-18-2009, 03:38 PM | #2 | |
Gone to greener pastures
Re: pcv valve need
NOOOOOOOOOOOOOOOOOOO! YES!!! Andy, LHM, did an excellent write up on this. I'll see if I can find it for you.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
06-18-2009, 03:39 PM | #3 |
Re: pcv valve need
No, don't plug it. Keep it. PCV stands for Positive Crankcase Ventilation. It keeps air moving through the crankcase and prevent vapors and backpressure from building up. The PCV is not robbing you of any power (one of the FEW emissions pieces that doesn't!).
So for your own sake, keep the PCV and prevent a possible implosion of fumes in your engine (it's been rarely known to happen). |
06-18-2009, 03:43 PM | #4 |
Re: pcv valve need
I found it!
Andy's explanation is about post #10, & it explains the PCV system in terms that even I could understand. http://67-72chevytrucks.com/vboard/s...ferrerid=32400
06-18-2009, 04:01 PM | #5 |
Re: pcv valve need
I can speak from experience here. Once upon a time I pluged my PCV valve with every intention on buying one on pay day.... being the procrastinator that I am I never did. That blow by gas is so caustic that it ruined every single seal and gasket in the engine (valves, front timing cover, rear main...ect ect) every gasket and seal was hard as a rock. I also learned from that how a rubber seal can ruin the shaft that is sealing once it can no longer lubricate it's self I was lucky and was able to use redi sleaves on the shafts. I agree with LHM in his post PCV is your freind.
06-18-2009, 04:59 PM | #6 |
Re: pcv valve need
great thanks, does it matter wich side its on, orig on right side with breather on the left ( if your looking from the fron), when I changed carbs it wouldnt reach so I moved it to the left and breather on the right
06-18-2009, 07:59 PM | #7 |
its all about the +6 inches
Re: pcv valve need
El Jay... thanks for digging that up. I was thinking about that the other day and thinking it should be in the FAQ since it comes up once a month or so.
As for what side to put it on, it does not matter at all. As long as you have the PCV valve on one side, and a vent on the other (vent being a tube to the air filter, or a simple breather) that is all that matters. |
06-18-2009, 08:39 PM | #8 |
Re: pcv valve need
Doesn't even need to be in the valve cover. Buick V6 had it in the intake but you need some sort of breather. SBC easiest thing is to choose a valve cover.
06-18-2009, 10:13 PM | #9 | |
Re: pcv valve need
When's your next visit? You know we'll treat you right, almost.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 06-18-2009 at 10:14 PM. |
06-19-2009, 06:07 AM | #10 |
Re: pcv valve need
71 tahoe, the valve cover is the best location for it, although you are technicly right, it can be placed in the intake.
el jay... I have NFC when I'll be back out that way. I wanna go, but short on vacation days, money, and everything else needed for that kind of adventure. |
06-19-2009, 01:39 PM | #11 |
Re: pcv valve need
Maybe Mike could get "haul" & need a co-driver?
06-19-2009, 03:48 PM | #12 |
Re: pcv valve need
I only have 4 vacation days left, until may. Even with a weekend thrown in there, it isn't enough time to haul out and back.
06-19-2009, 08:20 PM | #13 |
Re: pcv valve need
Oh, well. It was a thought.
You two ain't nuttin' short of a big ol' kick in the butt.
06-19-2009, 10:16 PM | #14 |
Re: pcv valve need
the way you worded that, I should say;
thanks? But knowing how you mean it... THANKS! |
