Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-18-2009, 06:28 PM   #1
1970bowtie
1970bowtie's Avatar
bbc opinions
ok, so im wanting to find a bbc block and build the motor as i have spare time. mostly it"ll be run on the street but may have an occasional pass down the track im wanting something in the 500 horse neighborhood. i want something reliable and strong that i can hammer down on and not have to worry bout blowing parts all over the place. so what would you guys suggest i look for to start with? the cheaper the better, i just graduated from high school and money IS an object. i know the majority of the money spent will be in machine work and rotating assembly.
oh and this motor will be for my 70 swb.
Justin
1970 c/10 short wide bed
WTT 1970 chevy front end for 67/68 chevy front end
WTT 2 15x10 american racing outlaw 2 wheels for 2 of the same in a 15x7 or 15x8
1970bowtie is offline   Reply With Quote
Old 06-18-2009, 06:49 PM   #2
vegaschevy
Re: bbc opinions
I asked this very question and never got really any solid answers. I am in the same boat. Doing a 454 stroked to a 496, aluminum heads, and shooting for over 500 HP. I ended up picking up a GEN VI block, ad will be installing some quality heads, intake, cam the works.
vegaschevy is offline   Reply With Quote
Old 06-18-2009, 06:52 PM   #3
454HO
Re: bbc opinions
Find a good Mark IV block, 2-bolt is fine. Get it cleaned up and see what size pistons you need. Then get a 496 rotating assembly. Look for forged pistons that will allow you to get to 9.5:1 static compression with open chamber heads. Then get some 781 or 049 heads and put 2.19/1.88 valves in them and pocket port. Grab an RPM intake and a 750 vacuum secondary carb. Use a Lunati Voodoo cam with 230ish intake duration and a set of 1-3/4" headers. Simple 500HP and 500lbs of torque.
- Greg
454HO is offline   Reply With Quote
Old 06-18-2009, 07:21 PM   #4
1970bowtie
1970bowtie's Avatar
Re: bbc opinions
so my best bet would be to start looking for gm vehicle from 65-74 correct me if im wrong on dates there... 73 or 74 454 out of a 3 quarter or one ton would be what i need
Justin
Old 06-18-2009, 07:32 PM   #5
1970bowtie
1970bowtie's Avatar
Re: bbc opinions
what about 74 down are those gen 5 blocks? i dont know much abt big blocks but im trying to learn before i jump off into it so be patient lol
Justin
Old 06-18-2009, 07:39 PM   #6
1970bowtie
1970bowtie's Avatar
Re: bbc opinions
nevermind i got in now gen iv were produced from 65-90
Justin
Old 06-18-2009, 07:54 PM   #7
Rodms
Rodms's Avatar
Re: bbc opinions
Did you say you were going to do a solid roller cam?
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 06-18-2009, 10:00 PM   #8
vegaschevy
Re: bbc opinions
When? where? not that I recall... never know, I was really tossed for ideas before getting this block
Old 06-18-2009, 10:43 PM   #9
joeys66pickup
Dr. Frankenstein
joeys66pickup's Avatar
Re: bbc opinions
solid cam...roller or flat tappet Its all good Make more power and get to set valvelash(hey the more i get to work on it the more i Smile)
I Wanna Go Fast!!
joeys66pickup is offline   Reply With Quote
Old 06-18-2009, 11:52 PM   #10
BossHogg69
motor exploder
BossHogg69's Avatar
Re: bbc opinions
I think he misunderstood when you said you didn't get any solid answers in your thread....
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-19-2009, 02:38 AM   #11
Outlaw72
Hay Team!!
Outlaw72's Avatar
Re: bbc opinions
If you are on a really tight budget.......just pick up a solid 454 core and put some 781 or 049 ovals on it. Decent cam, airgap intake and some roller rockers. It will run just fine and take a ton of abuse if the right person builds it. I had this in a 72 LWB with 150 shot and ran some 7.30's in the 1/8. That's plenty fast for a kid out of high school
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 06-19-2009, 03:50 AM   #12
dragula
Re: bbc opinions
Find you a good marine place. Alot of rich guy's usually take out small motor's to put in bigger ones. Most mercs. are square port heads, steel crank, 7/16 rod and are usually balanced !
dragula is offline   Reply With Quote
Old 06-21-2009, 09:06 PM   #13
c-tenkid
Re: bbc opinions
The gen 5 bbc started in 1991 and went on to 1996.I have a 1993 version of the motor and it's lame.Rated at 230hp and 390 ft pounds.The heads on the motor limit it to around 4500rpms.The gen 5 motor will not work with the mark 4 heads.Water jackets are different.
What you want is a one of the mark 4's.I also have a 454 and a 396.Parts are so much easier to find.And cheaper.They have adjustable valvetrains.
The good thing about the gen 5 is there cheaper.I bought mine with the serpentine setup and all the TBI harness and computer for 650 bucks.Complete good running engine.I see them on craigslist for around that money alot.
The older one's are ussually fetching more money.And are more worn out ussually.
69 c-10 lwb,Converted to 4x4,dana 44f,12blt,4 inch lift,vortec headed 355,th350/np203 34x10.50x15 swamper tsl's
c-tenkid is offline   Reply With Quote
Old 06-21-2009, 11:26 PM   #14
1970bowtie
1970bowtie's Avatar
Re: bbc opinions
yeah ive been looking around the net and it looks like ill come out better to buy a whole truck. also i know of a junk yard not too many others know abt, maybe i can find some good casting heads there
Justin
Old 06-26-2009, 01:07 AM   #15
85sqbdy
85sqbdy's Avatar
Re: bbc opinions
Go to your local pic-a-part a look for a 96 and up 3/4 ton suburban. some of them came with 454's. They were GEN VI at that point. When the great minds at GM decided to retool the mark IV 454 the GEN V was born. The GEN VI is a great foundation for a killer bigblock powerplant. I have one in my 85 and it has killer low end torque. Stick a big hydraulic roller cam in it and clean up the heads just a little and be ready to be impressed. Mine has a th400 w/a 3800 stall converter, and 4:56 gears so it's even more of a monster. But one things for sure, do your research before you lay out the green.
if it ain't broke, fix it until it is.
85sqbdy is offline   Reply With Quote
Old 06-26-2009, 06:49 PM   #16
royo
royo's Avatar
Re: bbc opinions
Whatever you do just keep it simple you dont need big heads or cams
nickle and dime
royo is offline   Reply With Quote
