Old 06-18-2009, 07:19 PM   #1
pcmcobra
pcmcobra's Avatar
McGaughys rear big brake kit arrived
Came today. Looks pretty solid. A few scratched on bracket, nothing a little rattle can will not fix.
Came with brake hoses, ebrake and cables. Only issue is where rotor fits on axle flange will need to turned a bit to get it to go on, even the instructions say this. No big deal really.
Will update when I get the kit on.
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 06-18-2009, 07:25 PM   #2
LiveAnimals
LiveAnimals's Avatar
Re: McGaughys rear big brake kit arrived
Pretty slick, its going to make a big difference
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 06-18-2009, 07:34 PM   #3
menace121978
menace121978's Avatar
sweet setup man. cant wait for mine
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 06-18-2009, 07:47 PM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Do they make this for 14 bolt? Where did you get it?
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-18-2009, 08:17 PM   #5
pcmcobra
pcmcobra's Avatar
I got it from stylintrucks for 539.00 shipped to my door.
Not sure if they make a 14bolt version.
Old 06-18-2009, 11:42 PM   #6
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Where is the new proportioning valve?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-19-2009, 07:21 AM   #7
silvereagle07
silvereagle07's Avatar
Looks like a nice setup. Does it come with backing plates and a prop valve? What has to be turned on the rotor, the hub hole?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 06-19-2009, 02:09 PM   #8
pcmcobra
pcmcobra's Avatar
no prop valve, I gotta get one.
And yes the hub hole needs to be turned.
Old 06-19-2009, 02:40 PM   #9
Eighty-6
If they know this I wonder why they just wouldn't fix it at the factory?
Eighty-6 is offline   Reply With Quote
Old 06-19-2009, 06:29 PM   #10
whiskeydented
whiskeydented's Avatar
I just bought the brackets for disc on a 14 bolt off of pirate4x4.com. The brackets I bought use all the front brake parts from a mid seventies chevy dana 44. I am swapping out my d44 for a d60 so for about 50 bucks I'll have rear discs.
whiskeydented is offline   Reply With Quote
Old 06-19-2009, 09:19 PM   #11
pcmcobra
pcmcobra's Avatar
maybe 10 bolt flanges are a little smaller than 12 bolt? Dunno, too lazy to take the drums off my 10 bolt to find out. Rotors/axles are at machine shop now ...
Old 06-21-2009, 09:18 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
Do you have any idea what the rotors fit? Are they custom made for a conversion application, or OEM replacements? I see they are drilled for dual pattern. Any idea what the other pattern is?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-21-2009, 10:23 AM   #13
pcmcobra
pcmcobra's Avatar
Ken,
I am not sure if they are custom for mcgaughys kit or not. The other bolt hole pattern I believe is 4.75.
Old 07-02-2009, 04:40 PM   #14
pcmcobra
pcmcobra's Avatar
Well, BAD NEWS.
guy called from machine shop today, so I went down there this afternoon.
Per directions, I knew the inside axle flange hole would need to be opened up a little, BUT, even with that the rotor will not sit flat on axle flange. You can either machine the inside of the rotor, or machine the outer flange of the axle, I did not want to do either, you would end needing to take almost 7/16 of material from one or the other, or split the difference, and hope the brackets and caliper line up. I called mcgaughys, and they verified this would need to be done, but it does not say this on their site or in directions(only machine rotor hole or shaft flange on end to get it to sit over flange.)
Anyway, after much frustration, I sent them back.
Seems like I will never get this rear end done.
So just an FYI for anyone interested in this brake kit.
Old 07-02-2009, 05:44 PM   #15
menace121978
damn buddy that is bad news... my kit from blackbirds arrived today and i got the brackets, rotor, and caliper on the driverside done. turned out real nice. you should call randy at blackbirds. i think he's putting together a 13" rear disc kit. real great guy to deal with... Dennis
"Dennis the Menace"
Old 07-02-2009, 06:04 PM   #16
pcmcobra
pcmcobra's Avatar
I might just do that!
thx
Post some pics..
Old 07-02-2009, 06:12 PM   #17
menace121978
just finished them up and me and wife are off to see public enemy. i'll post them up for you as soon as i get back. really happy w/ the look.
"Dennis the Menace"
Old 07-02-2009, 09:00 PM   #18
tvblazer78
Low & Fast!
tvblazer78's Avatar
Well, BAD NEWS.
Man that dose suck, sorry about that. They did look cool but that dose not help fi they do not work. Like Dennis said blackbirds kit works very well, that is what I used.
tvblazer78 is offline   Reply With Quote
Old 07-02-2009, 11:45 PM   #19
menace121978
sorry took so long photobucket is sloooow tonight. as promised....
here is how the kit looks. keep in mind that this is the non e brake kit w/ 11 5/8" (about) rotors.
i grinded down the casting for a smooth finish.
"Dennis the Menace"
Old 07-03-2009, 11:41 AM   #20
3r!c84
Badass
3r!c84's Avatar
menace121978
did u do a flip kit on that
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-03-2009, 12:24 PM   #21
pcmcobra
pcmcobra's Avatar
looks good!
Old 07-03-2009, 03:30 PM   #22
menace121978
Originally Posted by 3r!c84 View Post
menace121978
yep.
"Dennis the Menace"
Old 07-03-2009, 03:31 PM   #23
menace121978
looks good!
thanks man... hopefully they stop as good as they look!
"Dennis the Menace"
Old 07-03-2009, 08:14 PM   #24
spr85gmc
spr85gmc's Avatar
more info on the set up truck looks sick...
spr85gmc is offline   Reply With Quote
Old 07-03-2009, 08:31 PM   #25
boatpuller
boatpuller's Avatar
that sucks cobra........hopefully you'll have no prob on the return and then get that blackbird setup,it look's nice.good work menace.i like it.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
